Question about Elna Sewing Machines
My Elna Star Deluxe Machine has stopped zig zagging. Is this a quick fix?
My machine will not zigzag stitch correctly. The needle goes through on the left, makes a hole on the right, but the thread (bobbin?) does not go through and form a locking stitch. Not sure what to do.
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Posted on Aug 21, 2009
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
Posted on Feb 13, 2010
ELNA 62c, AM UNABLE TO ZIGZAG WITH IT. WHAT AM I DOING WRONG? DOES THE ZIGZAG HAVE ISSUES & WEAR OUT? IT TRIES TO START TO MOVE THE NEEDLE OVER BUT IT DOESN'T DO THE ZIG ZAG STITCH.HOW CAN I FIX THIS?
From the info I found, this appears to be an older mechanical machine. If so, most likely it is seizing due to lack of frequent oiling and cleaning. AVOID using the machine until you get the issue resolved as it could damage the motor. The following may be helpful in getting your machine back to working again. Lack of oil can affect many different moving parts in the machine. It just happens that it has first appeared with the zig-zag capability of your machine. Apparently, manufacturers did not anticipate these machines would last so long--they assumed the machines would be periodically maintained by a professional technician who would regularly oil. As a result, many of these great machines have been sidelined simply for lack of oil... but they can be brought back to life.
Wheel on right side that controls the needle up and down is very tight...
http://zengrain.com/elna-elnasuper-62c-sewing-machine-manual
May 09, 2017 | Elna Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
Elna 3210 raw-edge zig-zag stitch bunching
Zigzagging on the raw edge of a lightweight fabric will pull up, because the needle is swinging to the right side off the fabric, bet solution is to use the three step zigzag to overcast the raw edge, it looks like a zigzag mad of dots in the stitch icon. Dont know your model well, but its late model so should have this stitch.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
Raw edge zig zag stitch bunching underneath
When zig zagging over a raw edge, the tension on the thread will pull in the fabric, especially in lightweight cottons or even lighter organza. Its not the best edging method for very light weight fabrics. You can try using a smaller zig zag, loosening off the top tension a little bit. Or if your machine has it, use the triple zig zag or serpentine stitch, where the needle goes through the fabric three times to make up each zig stitch, this stitch is better for edging most fabrics and is my preferred stitch.
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
My Elna SP suddenly stopped making the normal stitches regardless of whether I turn the stitch guide to "normal," "zigzag," or "overcast" mode.
Have you also turned the stitch width lever to 3 or 4 to form a swing needle type stitch?
Is this a Lotus SP or a Star Series SP? They should both have a stitch selector, a stitch width dial and a stitch length dial. Stitch width usually 3 or 4 and length usually at least 2 for a zig zag or overcast stitch. Also check the needle position dial, have you perhaps moved this off centre and not moved it back?
Mar 03, 2011 | Sewing Machines
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the underside....how can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
NEXT
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Jan 15, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Zig zag won't work
Make sure stitch width slider is not set to zero. If not then you either have a bind in the needle bar pivot or an electrical problem (bad stepper motor or bad circuit board).
I can't remember if this machine has a twin needle lock out, if so turn it off.
Good Luck!
Jan 28, 2009 | Elna 2007 Mechanical Sewing Machine
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
