Question about Frigidaire Dishwashers
Ffbd2406ns0a Cant get through a full cycle without it leaking...a lot. Ive only had it a couple of months and its only been used a handful of times. The door gasket/door wiper down on the bottom of the door has a gap in the center of it that is missing, but the pictures I have seen online show that it seems to be made that way?
  • 3 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Posted on Aug 25, 2007
SOURCE: Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Posted on Mar 31, 2008
SOURCE: Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Posted on Dec 20, 2008
baccardo
  • 150 Answers
SOURCE: Soap and water coming out the front of the dishwasher
yes you should compare the gap to a simular model then order the seal
Posted on Apr 18, 2009
  • 686 Answers
SOURCE: Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
Posted on May 01, 2009
Whirlpool WDF520PADM Clean Light not coming on when cycle is done?
Hello. The main control board is defective and its part number is W10650774. However, your unit should easily be under the manufacturer's warranty which covers parts and labor. The light is not from L.E.D.'s on the control panel but from lights mounted on the main board and channeled through plastic light pipes so they can be seen on the control panel. A lot of dishwashers have control panels with L.E.D.'s mounted on a circuit board and connected to the main board with a flexible wiring harness--yours isn't one of those types. Call for service so you won't violate the warranty! I hope I helped you!
Oct 09, 2015 | Whirlpool WDF520PADM Full Console...
18 month old kitchen aid kudc10fxss leaks water at bottom of door
Someone may've accidentally put liquid dishsoap rather than dishwasher soap into the fill cup. The bubbling will cause lots of foam to rise up above the float-switch without actually raising the switch (shutting off the water supply). Lots of helpers on the web recommended draining, wiping out the foam, pouring in a cup of vinegar and a handful of salt and running the rinse cycle a couple of times. It worked for me!
Feb 25, 2013 | KitchenAid KUDC10FXSS - KitchenAidR...
I have used the machine a couple of times since I posted and have not noticed any leaking yet, but I used only the gentle cycle and the quick wash. When there is leaking, it seems to come from under the...
check hoses for leaks and dont over load it the weight when its full of clothes and water is quite a lot the swaying about with weight in it might be making a pipe pull causing it to leak
Aug 24, 2012 | Haier HLP21E Top Load Washer
Dirty steaks on clothes at end of wash cycle.
Make up a couple of liters of a strong solution of hot water and Soda Crystals, pour that mix into the machine without any laundry in it and do couple of very hot washes
Change your soap powder to one of the old fashioned ones for a month or so and see how you get on.
Cold washing tends to leave body fats and other greases inside the machinea s there is little to break them down in "Modern" powders
Jun 19, 2009 | Washing Machines
98 jaguar xj8 won't start
Ten is not a problem persay but is it a traffic light to light ten miles? never really hittin any highway? If so ive seen lots of plug fouling from short trip situations like that. nothing wrong with car mechanically at all--just the way v8's are. They need taken out and run hard every couple months. Pretend your in the cannonball run--less your area is like mine and crawling with police :) Thanks hope I helped.
Apr 06, 2009 | 1998 Jaguar XK8
Ive never used the computer for couple of months now i cant used the internet and i cant download any games .. can somebody help me ?..
Hi There,
Could you please tell me the reason why you stopped using the computer and more importantly was the computer working fine at the time you stopped using.
I look forward in hearing from you.
Regards,
Philip
Dec 01, 2008 | HP Computers & Internet
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Mar 23, 2008 | Hoover AAA140 Front Load Washer
Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Oct 08, 2007 | LG WM1815CS Front Load Washer
Dishwashers Logo
60 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
