Question about APC Back-UPS 200 UPS System
APC Backup UPS Model # BK200C salvageable?
The Backup UPS Model # BK200C that I purchased 10 years ago was never used. After I plug it it to an outlet and the I/O switch lights up, does that indicate that the unit is still operable? Otherwise, can the unit still operate as a surge suppressor if the battery is removed without replacing?
  • 565 Answers
Yes, but the battery may not be any good, though, and trying to charge it may damage the charger. A new battery is about $20. The surge suppressor will still work without the battery as long as it is connected to a properly grounded 3-wire circuit. If you decide to take a chance and charge the old battery, take precautions like keeping a watch on it should it explode or catch fire. Not trying to scare you, just looking at worst case scenario.
Posted on Jan 27, 2009
What causes damage to the IC called TNY275PN in APC RS 600 UPS??
Buy the APC SMART UPS 1000VA or higher. Those can allow setting of norminal voltages and boost or buck limits. The Boost and buck of Smart UPS function like an Automatic voltage regulator.
The cheaper UPS are built for nominal voltage of 230V +- 10% and cannot be changed. Overvoltage is cause of your UPS failure.
Jun 16, 2014 | APC Back-UPS 600VA UPS System
Why does my APC Conext UPS beep after power is restored?
After about 2 to 3 years the batteries usually have to be replaced. I found with our UPS's we get about 3 years maximum from the batteries. Ordering the originals from APC is rather expensive.
Locate a professional battery distributor in your area. Get the part numbers written on the batteries in your UPS, and including the detailed descriptions. You can then order these from the distributor. APC uses industry standard batteries. We found the Panasonic and Portilac brands to be excellent.
APC manufactures the UPS's. They use various battery manufactures depending on bid costing.
Jerry G.
Jun 29, 2012 | APC Conext UPS System
I get an alarm with continuos beep sound everytime I plug in the unit, even without load
Time to change the batteries. Open the UPS and get the battery type numbers and spec written on the batteries. Locate a local battery distributor and you can order batteries. APC uses industry batteries.
The batteries last an average of 2 to 3 years. They wear out inside. You can also order APC original batteries if you feel insecure about purchasing them from a battery dealer. APC will charge more for the batteries, but they will be original to the UPS type.
Jerry G.
Jun 25, 2012 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
After a four day power outage, my APC BE325R buzzes continuously when started, even though nothing is plugged into it. Has the battery suddenly died, or does it require recharging? Its a very loud buzz -...
It is probably a bad battery. They usually don't last much longer than 2-3 years. You could try replacing the battery, but I would suggest just replacing the whole UPS with a new model.
Sep 08, 2011 | APC BE325 SURGE PROTECTOR + BATTERY...
We have apc es500 we used almost 2 yrs and now its not working, possible to repair? but if not do you have any idea where we can sell it for disposal. thanks
Contact APC.com
Here is the page for your model , it looks like it qualifies for the tradeups program. Or you can purchase a battery for it and fix it yourself.
http://www.apc.com/tools/upgrade_selector/index.cfm
Jul 13, 2010 | APC Back-UPS CS 500VA UPS System
Smartpro UPS dead
APC UPS not turn on if battery are dead (zero volt) or un-plugged.
Oct 16, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
Back UPS Model # BK200C salvageable?
Yes you right you can just use it as surge protector, but it would be better if you gonna buy a battery for that unit aleast you got a back up in the event of power outage.
Jan 27, 2009 | APC Back-UPS 200 UPS System
Unit is switching to battery power for now reason.
Any UPS monitors the incoming AC level to determine if it is needed or not.  I think the APC unit doesn't know any more when it is needed; it's sick.
Sep 23, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
APC Back-UPS 200 UPS System Logo
384 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
