Question about Kenmore 24 in. 15932 Built-in Dishwasher
No water I have the kenmore ultra wash quiet guard built in. You can hear the motor running but it is not drawing water into the machine. I have checked all of the hoses and connections and they are good....pump sounds like its running but just wont draw the water in.
  • 2 more comments
  • G4RC Jan 27, 2009
    Okay, have established that it is drawing water into the unit but not pumping it through.
  • Anonymous Feb 11, 2009
    kenmore dishwasher model 15951
  • Anonymous Feb 12, 2009
    water is not geting to the dishwasher
  • sndmiller Apr 23, 2009
    I have the same issue right now. I don't know what an inlet solenoid is, or I'd check the wiring on it- any advice? Also, if the pump impellor is broken, is it time to get a new dishwasher? Thanks!
  • 142 Answers
Inlet solenoid not working, check wiring is attached
Posted on Jan 27, 2009
  • shyspeed Jan 28, 2009
    if the water is going into the machine, and the filters are not blocked, and the pump is running, the pump impellor might be siezed or broken.
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Door won't lock on kenmore ultra wash quiet guard 3
I would say it's worth getting a Professional to repair the door. It saves a lot of time and effort in the long run...and money! We had the same problem and no way could we have fixed it ourselves.
Jul 06, 2014 | Kenmore 24 in. 15689 Built-in Dishwasher
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwaser does not fill
Hi. You can test the fill valve for voltage. If it is getting 120V and n water is coming in, change the valve.
Some models you can pull the float out.
When you lift it up and down, can you hear it clicking?
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Does not appear to wash
is there a low humming noise when it should be washing? if so may be the motor capacitor
Apr 02, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
378 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
