Question about Kenmore Freezers
Electrolux ken more elite freezer door alarm going off with door closed
5 Suggested Answers
  • 115 Answers
SOURCE: I woke up to an
if it can be turned off it will be in the kickplate but the alarm will go off when it gets back down to temp
Posted on Jan 03, 2009
  • 61 Answers
SOURCE: freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Posted on Jul 06, 2009
  • 4793 Answers
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Posted on Feb 11, 2010
bidniperth
SOURCE: electrolux chest freezer alarm
Freezer try to start but overload cut out
Posted on Nov 08, 2012
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Factory reset for electrolux appliance
in order to solve a problem you need to understand how the device works. ideal for sensing the status of appliance doors
whether in the open or closed state (or for internal light). in the door under insulation (not visible) is a permanent magnet which switch on or off reed switch (usually on electronic). when the door is closed, the permanent magnet close or open the reed switch, depending what kind of switch is, normally open or normally closed. electronic received that information and because that (open door) stop the cooling fan. so, in your situation i would like to check that door is not hung up for some reason or try use an external permanent magnet. of course, reed switch should be checked also, because sometimes contacts may remain closed.
see the pictures below,
factory-reset-electrolux-appliance-tfdolxcnkaipunda4diszd1y-5-5.jpg factory-reset-electrolux-appliance-tfdolxcnkaipunda4diszd1y-5-9.jpg dado
Jul 28, 2014 | Electrolux ICON Professional E24RD75HPS...
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My kenmore frostless 16 upright freezer alarms
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Alarm goes on then turns off
May 12, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Food is not completely freezing in spots
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
May 03, 2010 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Feb 05, 2010 | Freezers
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
Nov 12, 2009 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Freezer door of electrlux freezer keeps coming
Jul 06, 2009 | Freezers
Freezers Logo
12 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
