Question about Reddy Heater-30-55,000 BTU Variable
MY KEROSENE HEATER STARTS, RUNS MAYBE 5 MINUTES THEN SHUTS OFF
USING GRADE A KEROSENE. WILL NOT STAY RUNNING.
STARTS, THEN SHUT OFF ANYWHERE FROM 1 TO 5 MINUTES LATER
  • 92 Answers
Same problem I had and it was the CAD/flmae sensor. you can get one that will fit from Mr. Heater for 3 bucks or from reddypats.com for 18. the wires are a different color but all you do is clip them and splice them to your old wire harness. It does''nt matter how you hook them as there is no hot and ground just a complete circuit.
Posted on Jan 27, 2009
Starts runs for 3minutes then shuts off
pressure should b at 6 to 6.5 clean nozzle check for cracks in air ling and fuel make sure both filters r clean and the flame sensor is clean good luck
Dec 07, 2013 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have an All Pro 150000 btu kerosene / diesel torpedo heater. It runs for a few minutes and then starts sputtering, shooting flames and smoke. What causes this problem?
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
My heater starts fine and runs maybe 5 minutes then shuts off. Any clue where I should start looking?
Here is a tip about troubleshooting Torpedo Heaters
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Jan 12, 2010 | Milwaukee Tool Master Heater B200 Series...
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
349 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
