Question about HP Compaq nx6110 PC Laptop
Computer will not go into STBY or Hibernate when lid is closed
Gateway 200ARC. Changed screen & motherboard, kept orig hard drive. Display pwr options/advanced/ pwr options box is checked for "when I close the lid of my portable computer it go into STBY." What is the trigger for lid close sensing? or Is my problem a software driver problem?
  • terryh5 Jan 27, 2009
    where is the switch under the screen to base? Do you know how it works? I do not see any mechanical switch like on other laptops.
  • terryh5 Jan 28, 2009
    Thanks for trying, but there is no such device on the Gateway 200ARC. It has to be a prox sensing device because there is no mechanical switch. The latch also doesn't have any other function other than to hold the cover closed. I have had the whole computer apart and can't find what triggers the close signal. I'm baffled!
  • 142 Answers
If the option is checked, and it doesn't work, the switch under the screen to base closing needs to be adjusted/replaced. i would double check settings and intallation disk if this does not work.
Posted on Jan 27, 2009
  • shyspeed Jan 28, 2009
    the little switch if a piece if plastic protruding near the hinge of the monitor, that hits a little button/switch in a cutout on the base/ keyboard.
    my acer and many others have them in various places.
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
Dell Vostro 1310 - when turned on screen still blank, numlock blinking, capslock and scroll lock light on and stable. tried changed new RAM,issue still persist. whats wrong with it?
it may be bios problem or loose connection with Hard disc... So, follow the below steps: 1.remove the battery and power adapter the power on button 2 minutes 3.replace the battery on the laptop normally... now see the result.... ---------------------------------------------------------- if not solved then follow the below steps
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 3.replace the battery on the laptop normally... 5.if any display appears then problem with ur hard disc or cd/dvd drive.
------------------------------------------------------ follow the below steps to check the problem with your hard disc or cd/dvd drive
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 6.connect the cd/dvd drive 3.replace the battery on the laptop normally... 5.if any display appears then the cd/dvd drove has no problem,then problem with ur hard disc drive. ---------------------------------------------------
Apr 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Oct 01, 2009 | Dell Inspiron 1300 Notebook
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
Gateway 200ARC goes to "Last Known Good Configuration" screen
try reseating the dvd drive and then go into the BIOS to be sure that the drive is being recognized. Actually go into the area of the BIOS that shows the name of the dvd drive that it recognizes.
It it does recognize the dvd drive properly then try other boot cd's. It still may not recognize them.
If so try another known good dvd drive in the laptop and if you have the same problem then take out the hard drive and then see if the system will boot up off of the dvd drive then. If it still doesn't boot then the motherboard is bad.
If it does boot then that means the new hard drive is bad and shorting out the dvd drive controller on the motherboard and the hard drive would need to be replaced.
Hope this helps clear up things for you and sorry for not responding sooner.
May 18, 2009 | Gateway 200 ARC Notebook
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
HP Compaq nx6110 PC Laptop Logo
111 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
