My computer seems to be overheating I'm not positive. It randomly shuts down and then when i turn it back on it gives me the usual start up screen but with white lines on the left hand side only and after that to the load up screen to vista i get gibberish running down in the same area. Any suggestions?
  • 1 more comment
  • mechanize Jan 27, 2009
    thanks a lot guys ill try all of your suggestions!
    Okay tried both of your suggestions. (okay when starting up its little black dots forming lines going down the left hand side sorry for the miscommunication) I tried the restore point but I guess for some reason one of the points didnt save so I have none sweet deal! Also it doesnt allow me to go go anywhere past the windows load up screen
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    This seems to be more a monitor problem than the computer. Do you see the same if you try a different monitor?
  • 585 Answers
The crashes have likely corrupted the boot record on your hard drive. there are some utilities that may be on your windows install disk, or perhaps your anti-virus installation disk. You are looking for something like FDISK/MBR OR FIXBOOT. There may be similar utilities if looking at the A-V disk.
After you restore the boot sector and get the system up again, set that restore point you mentioned. Then you still need to address the original heat problem. Suggest you check the heatsink on the processor, remove excessive dust dragons with compressed air.
Also inspect the motherboard for defective capacitors. Bad caps will cause such issues, I've had them myself. Bad caps usually show visible signs such as swelled ends. A good tech with a good iron can remove and replace the caps, and the parts are cheap. Or you can replace the Mobo but that means a fresh install of windows.
Posted on Jan 27, 2009
  • 51 Answers
  • Perhaps it's overheating, or maybe your graphics card is?
  • I'd suggest, if it's a desktop, to open it and make sure you see and hear that all the fans are running properly.
  • As an extra troubleshooting step, have a big fan of some sort Safely blowing into the open case of your computer
  • Then start up windows, and see if it cuts off like usual.
If it does, maybe it's not so much of a heat issue, So put everything back together like usual.
  • Then you could 1st create a System Restore point (in case something goes wrong,but if you do it right, it should be fine), and then after doing so, try reinstalling your Display driver.
  • If that doesn't fix it, you can just use System Restore to restore your computer back to the point before you reinstalled the display driver (if doing so messed it up somehow.)
I hope this Helps.
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
Tachometer drops low
vacuum leak usually increases rpm--the electrics got hurt from overheat--hav a data stream run-displays values of evry component-so u kno what parts are bad----private mechanic not a dealer- a scanner that uses factory gear not a 30$ tool sold in stores--the vehicle computer may hav an issue-a readout wont disclose it--so disconnect batt n see if problem clears or pull plug on computer and clean the pins--may reboot
Dec 16, 2013 | Buick Rendezvous Cars & Trucks
Computer Randomly Shuts off
If it only seems to be shutting down when connected to a 2nd screen, it's your GFX card that's overheating.
Normally, you'd hear a beep or two before it dies, but that would only be if you have the pc speaker connected to your motherboard, and also only if the card manages to send the error to the motherboard before it shuts down.
I'd suggest trying to cool down the inside of your case a bit more - add an extra fan or two to get the warm air out. If the card you have is nVidia there is a gadget that tells you the temperature of your card - you can find it on Microsoft's Win 7 gadgets page. I'm not sure if there's a similar gadget for Radeons.
If the card is overheating, that gadget will show the operating temp, and give you an idea of what you may need to do (and it's free)
Sep 14, 2012 | CyberPower Computers & Internet
My TV keeps turning itself on/off at random times, sometimes it works, then turns itself off, and flashes on and off! Its becoming really frustrating as it seems to only work when it wants to for a short...
This could be caused by poor ventilation on the unit. The back of TV sets where the air vents are usually located are meant to be easily accessible to air. When they do not have enough air then the Tv tends to shut itself down due to overheating when it geths too hot.
Try relocating the TV position to an airy environment.
Hope this solution has been helpful?
Sep 26, 2010 | Televison & Video
Emachines ET1810 desktop computer randomly powers down for seemingly no reason. Doesn't crash or freeze, just turns off, as if the plug was pulled. Started about 5-6 months after buying.
It could be overheating, and automatically shutting itself down, to avoid any damage.
Did you get the standard 12 month warranty when you purchased the computer? Did you purchase "extended" warranty? If so, contact Emachines, and get them to trouble-shoot and fix it.
Jun 11, 2010 | eMachines ET1810-01 PC Desktop
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
My laptop keeps shutting down at random times. I
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Toshiba Satellite Goes completley off! Black screen, NO POWER!
Hi Steven, in my experience as a tech support agent, it seems that you're having an issue with your hard drive, sometimes it might also be an overheating issue, to be clear on that, please be sure to check the temperature of the computer when it shuts down, then the first symptom of the issue seems to be the clicking sound which ussually comes from the hard drive's reading head, this might indicate the hard drive is damaged and that it cannot perform as usual. The steps to troubleshoot the issue will be as follows; First please enter the BIOS/ System Setup of the system, by pressing the [Delete] as soon as the computer turns on several times, you will appear in a black or blue enviroment with some information from your computer. Check if the issue will happen there as well. Second, if the computer gets really hot at the point when it shuts down, please ensure that all the fans in the computer are running (you should be able to hear them), And be sure of the temperature when it shuts down, we must know if the computer is too hot to touch, or there is no problem with it. Third step, how long will the computer stay on? Will it always shut down at the same time?
The best solution for this issue would be to replace the hard drive, or defective fans depending on the troubleshooting results, if you're still within your 1 year warranty with Toshiba, you should contact their tech support team to replace the part.
As an aditional step to the troubleshooting you should also try to remove the hard drive, and let the computer on for as long as its necessary, to discard the hard drive from the issue, if it doesn't shut down then the hard drive seems to be the problem.
May 03, 2009 | Toshiba Satellite 1805-S274 Notebook
Whenever my computer starts up and shows the Windows XP logo it shuts down and shows me while starting up that windows wasn't started up rite. Than after a week it COMPLETELY messes up. I've tried a FULL...
It is one of 2 things....
1. It is overheating. Overheating will cause the computer to randomly shut down. You can usually decifer if it is overheating by trying to put the computer back on after it shuts down. For example , start it up...let it shut down...then try to put it back on again...if it doesn't come on at all, or if it shuts down even quicker then the previous time, you are most likely looking at an overheating issue. To remedy that you want to open up the case, clean out all of the dust with a compressed air can (be very careful not to tip the can, it will spray liquid), and verify that all of the system fans are running.
2. Could be any type of hardware failure - from the power supply to the hard drive. If you have completly ruled out the overheating issue, I would just take it to a shop to get diagnosed.
Feb 25, 2009 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
