Question about Channellock Channel Lock 4v Dual Driver
Channel lock 4v dual driver won't charge - Channellock Channel Lock 4v Dual Driver
Drill does not seem to be charging
you may need a new battery, their only good for so many charges.
Jul 05, 2014 | Channellock Channel Lock 4v Dual Driver
How to tell if charger is positive or negative?
Here you will found a possible solution: https://1drv.ms/f/s!AilOxaQiTdbQgdAbBgFAhCyiQS1HHg I include the manual and other considerations about the polarity,
May 21, 2014 | Channellock Channel Lock 4v Dual Driver
Manual download drill
"Manual download drill" - Please rephrase /clarify
"Cannot change bits" - More information needed.
Dec 26, 2013 | Channellock Channel Lock 4v Dual Driver
WHAT IS THE INPUT OUTPUT FOR CHANNEL LOCK 4V DUAL DRIVER XL CHARGER
you must see the label attached to your charger. However if the label is NOT ATTACHED, please download the o.manual go to www.retrevo.com or www. manualslib.com
Other alternative is that you know what voltage is using the device that you are using, read the label attached of the device, and you must sure what is the charger specification.
God bless you
Nov 28, 2013 | Channellock Channel Lock 4v Dual Driver
Where can I find a replacement charger for this?
any charger that meets the requirement of voltage battery type and charge rate and the battery pack just fits in will do the job. It has to be suitable for either a nic cad battery pack or ni hi battery pack which require different chargers
Jun 29, 2013 | Channellock Channel Lock 4v Dual Driver
How to charge my channellock 4v drill. Can't find the instructions book
Traditionally the charge port is on the heel of the tool, it will be no larger than a screw head. It will have a small post terminal in the middle of it. If it does not have such a port, look for a soft polymeric button, it should flip out. If not, see if the battery can be released, the grayish buttons on the bottom of the handle may be what you need to press to release the battery for charging.
Feb 14, 2012 | Channellock Channel Lock 4v Dual Driver
Battery will not charge
If you have DEEPLY discharged the driver, one or more cells of the battery have probably revese charged and shorted.They cannot be charged when this happens. Replace the battery is the solution.
Jul 31, 2011 | Channellock Channel Lock 4v Dual Driver
Channellock Channel Lock 4v Dual Driver Logo
267 people viewed this question
Top Channellock Drills Experts
Are you a Channellock Drill Expert? Answer questions, earn points and help others
