Question about Honeywell Programmable Thermostat Heater
Digital therm in apartment wont shut off
I have just installed this digital them. i know i have it hooked up right i have done many in the past and even looked at the directions. There is an override switch like a light switch that i can shut it off with but the heater/ac continues to run no matter what temp i set it at. Any help would be nice thanks
  • Jess n Jed T n B
    Jess n Jed T n B Jan 27, 2009
  • tanyalakos Feb 01, 2009
    Help,
    I have the same problem... anyone know how to fix it...
    My heating bill will be crazy...
    Heated UP... in Worcester, MA
    Problem Solver:
  • 15 Answers
I think the best thing you can do is get in a pro in and make sure it is all done the right way, as I got done the same way when I thought I had done it all right .
Posted on Jan 27, 2009
  • The StickMan Jan 30, 2009
    I have a another thing for you to try. What heating have you got
    as I mine started to play me up a bit and in the end it was a one of the Valves that where playing up try having a look at them give them a tap or if you can move them about a bit and see if that helps. I had to keep playing with mine for about three days and now it is working ok. They get stuck after sitting there not doing sometimes, I hope this is of help to you and wish you all the best with it. If that not working get back to me.
    Rgs
    The StickMan
Dgs 160 Note if sd card is installed is on the
What size memory cards are you trying to use? The I-60 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 15, 2013 | Cameras
Hp laptop shut off on me
Remove the phone obviously it is not compatible with your laptop. Also I hope that you did not short out the board somewhere. Something spiked electrically maybe. It does not take much for this kind of thing to happen. Also try the power button after about a couple of hours with it unplugged remove the battery. See if it reboots again or comes on do not try to hook the phone to it. I assume it was a USB wired to the phone it could be a USB port shorted this happens. In any event as you know something damaged something if it will not power back on again.
Take to repair facility and see what they say after you let it rest you can take apart not recommended to see if there is any black or burnt spots anywhere on the board. I have done this back in my curious days of computing and lost computers doing things like this it is nothing you did. Just happens I know. "Its a machine" ..............John
Apr 10, 2012 | HP Computers & Internet
Tomtom Go930 wont accept full postcode
I did this same thing and it worked for me EXCEPT the guide for the copy n paste Via the Organiser button didn't work so just did the old right click copy the "zip" file and right click on tomtom folder in the +my computer" menu paste AND wala
Jan 16, 2010 | Tomtom GO 930 GPS Receiver
My Compaq presario V3000 laptop is not restarting if I reboot immediately shut down. But I can restart it after several hours after shut down. Pls let me know what is wrong with it.
Do not re-install anything...
It is an overheating issue. The "paste" between the processor and the heat sink has deteriorated over time and the heat sink is separated from the cpu or not making a good heat conduction contact.
Although it is possible for you to do (take laptop apart), I suggest a repair shop.... but get an estimate and have it done while you wait... don't buy any other "services"..
Hope this helps!
Sep 13, 2009 | HP Compaq Presario v3000z Notebook
Max-e-therm thermal regulator goes bad quickly
thats is related acid left on the pool corroded i service so many salt pool with this heater and not problems at all the awser was the PH WAS balance on the past or now but the problem wont stop there will be future damage to the heat exchanger. are you add tabs to the skimmer? what happend to the heater is because low PH. SORRY not easy solution but to balance the chems and replace any corroded part
Sep 01, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
My computer wont get past step one on the installation cd
what is the OS
it this is xp or vista you do not need to run setup
connect your pc or laptop using cable and
go to router home page using either 192.168.1.1 or look at the setup page it will give you what is the ip adddress for th home page
here you have to enable wireless and use this router
good luck
May 28, 2009 | Computers & Internet
Camera turns on and then right off immediatly
first if u want to get ur cam to work use energizer rechargeable batteries after charging them for sure this is the best kind u can use powerful and last longer ,to get ur pictures out u can take memory off the cam and put it inside memory card reader then plug it to ur computer through usb ,computer will read it easy and u can download ur pics to ur pc
Mar 27, 2009 | Vivitar ViviCam 3750 Digital Camera
1990 honda accord
If it is a three wire ox sensor then you must make sure that wires are hooked up right or it will not function and cause engine to run erratic. One of the wires are for the preheater in ox sensor so it must be hooked properly.
Aug 09, 2008 | 1991 Honda Accord
Smoking
Gee I would think that it is kind of obvious; your amp is blown. Just because it doesn't blow fuses doesn't mean much. If you hook the power up to the ground input and the ground to the power and then turn it on you pretty much toasted the amplifier. If you don't know why the amp is smoking, but you're trying to fix it yourself, you are basically telling me that you have no business doing so. I have been an installer for 15 years and even I am not dumb enough to try to fix a bad amplifier. Do everyone a REALLY big favor; stop messing around with something that you don't understand of have knowledge about before you hurt yourself.
Mar 16, 2008 | Legacy LA838 Car Audio Amplifier
Heating & Cooling Logo
57 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
