Question about Maytag PYE2300AY Electric Dryer
Maytag gas dryer
Smells of electrical burning
  • 29 Answers
Two highest probabilities are that the belt is worn and slipping on the motor pully or that the motor is drawing too high of amps, working too hard, wore out. Also if there is excessive lint in the internal air chamber this can also be a problem. To reduce the suction draft of your blower remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not runnig straight through then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. This wont really fix the main condition, but it will not hurt. Remember this tip on future driers and you will make the dryer blower motor last much longer and it will lower your energy consumption.
Posted on Jan 30, 2009
Amigaman
  • 248 Answers
SOURCE: Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Posted on Nov 11, 2007
docjohn174
  • 943 Answers
SOURCE: Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Posted on Sep 18, 2008
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • 351 Answers
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
Posted on May 09, 2009
Gas smell in maytag dryer
You have a gas leak from the gas valve being faulty. DO NOT use the dryer until you have replaced the valve! I have been doing appliance repair for 15 years and I have seen 7 homes that have burned down due to this very same problem. Please don't use the dryer! Here is the new gas valve to order.
Keep me posted!
Nov 05, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Burning smell but not odd sounds
make sure vent is cleared MDG is a gas dryer so sometimes when theyre heating it may smell different than youre used to. blower impeller wheel has a "D" shaped hole & can round out causing it to hang up the motor which could cause a burning smell but usually will make a lot of noise B4 that will happen.
Jun 29, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When I push the start button on my maytag neptune dryer it sounds
MORE TIMES THAN NOT, WHEN I HAVE SEEN THIS PROBLEM, IT TAKES A NEW MOTOR TO CORRECT THIS SITUATION. MAKE SURE EVERYTHING MOVES FREELY BEFORE CONDEMNING THE MOTOR THOUGH.
Jan 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Maytag mde9206ayw
HI WHEN YOU PUSHED THE BUTTON TO START DID IT HUMM IF IT DID YOUR MOTOR IS THE PROBLEM ESPECIALLY THE BURNING SMELL
May 24, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
