Question about Jl Audio 12W6v2 Car Subwoofer
Jl audio 10w6 x zapco350
Can i connect my jl 10w6v2 to a zapco 350,bridged into 2ohm?
or is 8ohm the only option?
  • 15,935 Answers
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
Posted on Jan 27, 2009
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
What would be the best settings on a pyramid arctic 1000 watt amp for one JL audio w1 12
Your sub is a 4ohm woofer, running it in bridged mode + on right connection - on left connect as market on sub will give the best output. Your sub is rated at 75w to 300w and in this configuration will be getting just over 100w which about all the amp can provide with your sub/amp combo.
I don't know where they get the 1000w rating from either? the maximum the amp can possibly provide is 150w if running a 2ohm woofer in bridged mode.
Mar 08, 2012 | Car Audio & Video
Hi, Does the amp run 1ohm stable?
No it depends on you speaker or sub right now i have one that runs 2ohm up to 8ohm what speaker do you have it will tell you what it can run in the owners manual to the speaker or sub also if you have dual voice coils you may have to wire it a sertain a the manual will also tell you.
Jan 16, 2011 | Jl Audio G1700 Car Amp
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
How many speakers and woofer solid audio f2000 2 channel amp can support ?
  • 8ohm Stereo / 1200 W
  • 8ohm Bridged / 3400 W
  • 4ohm Stereo / 2000 W
  • 4ohm Bridged / 4300 W
  • 2ohm Stereo / 2900 W
  • it can support 6 but i would use 4 but make sure the subs have more watts than the amp
    Jul 11, 2009 | Solid Audio Formula Series F2000 2-Channel...
    Dont know how to wire it
    Hi this is tech crazy.I find this to be your apt solution for the problem posted
    Feb 01, 2009 | Car Audio & Video
    I have 2mb quart 15's 2ohm sub and a hifonics bxi1608d amp
    The two 2ohm subwoofers can only be wired to a 2ohm or 8ohm load. You are gonna want them wired 2ohms on a monoblock amplifier. the other option is to wire each sub to 4 ohms (series) and then connect each one to a separate channel on a 2 channel (stereo) amplifier. go for an amplifier that produces up to the MB's RMS rating and make sure they are enclosed in a box to their specifications and they should pound.
    Jul 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
    Jl audio/1,
    there is a short check all connections carefully.. im betting it is your speaker connections
    Jul 26, 2008 | Jl Audio 1000/1 Car Audio Amplifier
    Jl Audio 12W6v2 Car Subwoofer Logo
    400 people viewed this question
    Top Jl Audio Car Audio & Video Experts
    Mark Skinner
    Tygh Duval
    Tygh Duval
    hoyzee1
    Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
