Question about Ovens
We have a 24 inch fridgidaire stove Model number CFEF259CHS1. I can only find one fuse that seems to be working but some elements on the stove and in the oven don't work or work intermittently.
Some elements don't work
johnrodgers1
  • 73 Answers
SOURCE: oven elements not working after a trip from the fuse box
need new element
Posted on Feb 06, 2010
  • 11800 Answers
SOURCE: Hi; I own a GE
There are no fuses inside your unit, only a few relays and 2 thermostats that are very easy to test with an ohmmeter. In your case the element has died of old age (the resistance inside it failed), the other one isn't far behind.
I seriously doubt you can obtain even a second hand element, finding a new one is practically impossible since production of this line of models ended in 2001.
I think it's time to get a new one.
Posted on Oct 22, 2010
livewire874
  • 618 Answers
SOURCE: I have a fridgidaire Model
Have the bake element checked and check the wires going to it .
Posted on Nov 01, 2010
  • 144 Answers
SOURCE: Hi, I have a maytag
Before you spend any money, try a "reboot". Shut off the breaker for at least 15 seconds, then turn it back on; see if that helps.
If not, the power surge may have fried the microcontroller. If you were actually hit with a power surge, the local power company may be responsible; they may make the necessary repairs for you, but you'll probably have to go to whatever state agency regulates the utilities.
Posted on Feb 10, 2011
richroth
  • 9472 Answers
SOURCE: Model : ACE 23300 S/N IMD
You will need to replace the oven temperature switch. I did not find any parts available for that unit to direct you to. Do you have anymore information on it?
Posted on Aug 03, 2011
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
Where are the fuses for the oven broiler on model # 9752834A
naps is asking oven element is not working or starting dosen't light up
Dec 07, 2009 | Stoves Ovens
Fridgidaire electric stove.Bottom oven element is not heating as much as it should.Any ideas.Thanks john
A calrod heating element either works or it doesn't. The problem will be in the temperature control or sensor.
Jun 11, 2009 | Ovens
Whirlpool electric stove
The ideal thing to do, would to be to replace the elements themselves. Most heating elements for stoves are universal and can be bought at lowes stores. I found your model number specific burner elements on a supply website for 42.00 each on the 8 inch and 35.95 each on the 6 inch elements. I am almost certain, you'll find these parts at lowes or home depot much cheaper. If this doesn't help, let me know, we will try another route.
Apr 15, 2008 | Ovens
Glass for stove
You need the full model # off the range not the owners manual
Jan 09, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
