Question about Scotch New-C25 - Heavy Duty Weighted Desktop Tape Dispenser, 3 core, Plastic, Putty/Brown - MMMC25
Instructions for scotch c25 tape dispenser - Scotch New-C25 - Heavy Duty Weighted Desktop Tape Dispenser, 3 core, Plastic, Putty/Brown - MMMC25
What makes duct tape stronger than scotch tape?
Duct tape is much stronger than scotch tape for a few reasons. The first being that it is generally wider than a roll of scotch. Also, duct tape is made using cloth and is even coated in polyethylene.
Jan 30, 2013 | Hardware & Accessories
How do you open a Scotch Tape Dispenser C60 to change the tape
The entire carriage lifts out using a good amount of lifting force. Slide your finger under the empty roll from the front of the dispenser. Apply upward pressure. You may be concerned that you will break the plastic roller, you won't. the entire carriage will pop up. When it does it's a simple matter to replace the old tape with a new roll. Snap the carriage back into place to use the new roll.
Jan 21, 2013 | Scotch C60 black 2 Tone Desktop Tape...
REFILL INSTRUCTIONS FOR SCOTCH C60
You have to insert your finger under the empty reel from the back of the dispenser and pull up with your finger. You might think that it will break, but it takes force and it will not break if done properly.
Aug 15, 2012 | Scotch C60 black 2 Tone Desktop Tape...
I am using Scotch Magic Tape 3/4" purchased from
I can't give you a refund, seeing that I don't work for Scotch, but you might have success if you go back to Costco, or if you call the Scotch company to complain about the lack of quality in their products.
Apr 04, 2011 | Scotch Magic Tape Multipack
The tape film has been torn. How can i re-attach it?
use scotch tape to reattach tape
trim carefully so no extra tape hangs over sides
the "magic" tape works well - it is one that dissapears more when you rub it hard
Mar 20, 2011 | TDK 8mm MP 120 Minute Premium Camcorder...
How can ii remove scotch tape adheasive from a metal table
WD-40 or lighter fluid removes adhesive pretty good, or you can go to any hardware store and buy adhesive remover.
May 17, 2010 | Garden
How do I remove scotch tape from paited surface? When I peel it, it takes off the paint. I used scotch tape to hang spider webs for a Halloween party and now I cannot remove the tape without taking off the...
Yikes, sounds like you had a bad paint job! I would try goof off the waterbased orange gel first.
Sounds like you may need to take a bit of the peeling paint to your local paint store and get them to match it. A chip at least the size of a quarter will help them. Then fill the chipped area's with Crack Shot filler and touch up.
www.outbackpaintingusa.com
Nov 02, 2009 | 3M Scotch Filament Tape Hand Dispenser...
I have a VHS tape that had the tape severed can I use regular scotch tape to repair?
Yes, but to minimize the possibility of tape head damage tape on the inside of the damaged tape (that is the side facing the cassete not the outward facing side) and trim the scotch tape slightly smaller then the tape so no scotch tape is exposed - note you still run the risk of head damage but I've done it many times b4 with no problem
Oct 19, 2009 | JVC DF420 D-VHS Tape
Broken camcorder 8mm tape
Hi There, You can fix your tape yourself. 1- wind out tape from both sides of cassette. 2- cut both sides to form straight edges. 3- cut a small thin piece of clear scotch tape. 4- from cassette tape, put both sides together with recorded side facing down-- in other words you will be putting the scotch tape on the inside of the recorded tape. 4- line up the two ends and splice them together. - cut the excess scotch tape from the edges. Make sure there is no sticky stuff left there because if there is, it could rip out your video heads. The tape should only be played once and at that time, should be rerecorded to dvd or another media.
Hope this helps, mr cicmo
Jan 12, 2009 | Sony Handycam CCD-TRV68 Camcorder
Scotch New-C25 - Heavy Duty Weighted Desktop Tape Dispenser, 3 core, Plastic, Putty/Brown - MMMC25 Logo
66 people viewed this question
Top Scotch Office Equipment & Supplies Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Mark Andrews
Mark Andrews
Level 1 Expert
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
