Question about Raypak 010104 P-R336A-EN-X 50 Natural gas heater 0-2000 ft elevation 230lbs
Sns error code
Getting a sns code on control panel display. Where is the sensor located on this pool heater?
In the header... Plumbing side
And wire plugs onto heat / control assembly board.
SNS indicates that the Temperature Sensor is out of range! There are two thermistors within that sensor, and if there is a difference of 2 degrees, the board will throw a Fault Code: SNS
check for good connection at board, and ensure the sensor is all the way seated properly in its well.
otherwise, it may be bad.
Apr 25, 2015 | Rheem M266A 266K BTU Pool or Spa Natural...
Fault code: BARO.
donde esta el termostato
Nov 13, 2013 | Cars & Trucks
Rheem 206 propane heater will not fire has code #sns what is the problem? the water is 65 degree.
SNS means the temp sensor is out of acceptable range. Could be the following:
1. Water temp is below 36 degrees F
2. The sensor contains 2 thermistors, if they are more than 2 degrees apart and SNS failure will occur
3.Loose or corroded connection at P1 on the main board
4. If the sensor has come out of the JACO fitting on the header, it may read a SNS failure.
Solution, visually inspect the connections for corrosion. If it looks ok, then replace the temp sensor.
Jan 01, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
When I put power to my unit. A Sn code appears. Great Lakes spa 1996 260E balboa wiring
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Dec 06, 2009 | Balboa Instruments Garden
My raypak heater is not working I have power but the screen is showing an error message SNS. What do I look for what sensor is not working.
Here is the link for the manual for your boiler.
http://www.raypak.com/uploads/6000.59R.pdf
SNS Sensor failure, Water temp. below 36°F
or above 110°F - The water temperature sensor has failed or a wire is broken. (page 35)
Jul 16, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Can't access aol mail in safari. I get the login page very briefly and then it kicks over to an AOL error page again very briefly then I get a 404 not found error. ...
Try emptying the cache.
Go the Safari:Empty cache...
Select "Empty"
(So far so good for me.)
(Safari 4.0.3 with OS 10.4.11 on MacBook Pro 15" 2.16 GHz Intel Core Duo)
Jun 30, 2009 | Apple safari
Raypak 010104 P-R336A-EN-X 50 Natural gas heater 0-2000 ft elevation 230lbs Logo
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
