Question about ICOM Informatique Icom IC-F11 5W 16ch VHF transceiver 2-Way Radio
ICOM F11 radio will not receive - ICOM Informatique Icom IC-F11 5W 16ch VHF transceiver 2-Way Radio
4 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: icom ic720a ham radio not transmitting, pliz help
upon what frequency are you trying to transmit?
Perhaps the radio is blocked from trying to TX on said frequency.
Posted on Mar 20, 2009
  • 12 Answers
SOURCE: ICOM IC-F11
Bad battery, Buy new one on ebay. Carl
Posted on Aug 10, 2009
aloha27
  • 693 Answers
SOURCE: On the ICOM M604 will not receive the weather
Hi!
This is almost ALWAYS caused by a problem (a short OR an open) in the coax cable from the VHF radio to the antenna. An easy way to check is to JUST insert the PL-259 connector into the socket of the radio, making sure that ONLY the center pin is making contact with the socket. If the weather channels come in clearly, then it's usually an easy fix. Simply check the connections at each end of the coax, looking for a poor center pin solder connection or perhaps a bit of the ground braid is shorting out the center lead. A magnifying glass is a great tool to spot problems.
If the coax proves NOT to be the problem, then the fault is likely to be in the radio itself and is probably a bad solder connection where the antenna chassis mount attaches to the PC board.
Hope this is helpful.
Good Luck!
Posted on Jan 09, 2011
ICOM 802 NOTRECEIVING
Check the speaker .it may be busted. If you hear any sound your receiver circuit is faulty
Dec 21, 2013 | Icom Radio Communications
Icom m36 will not receive. Speaker makes noise with squelch all the way up but just won't receive anything including weather.
You may have the CTCSS tone squelch enabled so unless a station you're listening to is encoding CTCSS tones, you won't hear the traffic you're expecting.
Oct 28, 2013 | Icom IC-M36 VHF Marine Radio
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Icom ic720a ham radio not transmitting, pliz help
Mar 17, 2009 | ICOM Informatique Radio Communications
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
I have some ICOM IC-F11/S VHF Transceivers. I am having a problem with one of them. When I put it on the charger, it emits 4 beeps, then the red and green lights flash on and off. I have changed batterys...
Sounds like an intermittent problem. Was the radio ever dropped or water damaged. I would have to open the radio to check for damage. I think i'ts a
good idea for a tech to look at it. The IC F21S is an inexpensive radio you might just want to buy a new one. A tech will charge you around $65 just to look at it and a new on is around $129.00. I list on ebay every once in awhile a repair special for $32.00. But is depends on the problem. Carl
Jan 22, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
ICOM IC-F11
May 17, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
ICOM Informatique Icom IC-F11 5W 16ch VHF transceiver 2-Way Radio Logo
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
barney2xbass
Level 1 Expert
Michel Laprise Sr
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
