Question about Kenmore 22422 Top Load Washer
My Kenmore Washing Machine wont drain or spin. Only a slight hum.
The machine is not draining or spinning. It will fill, but then it only makes a slight humming sound when the lid is shut. It will not run through the cycle at all.
  • annaandjason Apr 03, 2009
    Can you please provide me with the steps to repair this problem and also the best place to purchase the part?
  • 5,911 Answers
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. The humming sound you hear when the lid is closed may just be the timer motor running. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured. I hope this helps you.
If you determine that your lid switch is broken, please let me know and I will provide you with the steps necessary to repair it yourself (simple repair job). I can also give advice on where to purchase a replacement.
NOTE: Placing heavy objects on the washer lid can cause the lid to bow and also affect the way it contacts the lid switch.
Posted on Jan 27, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Whirlpool washing machine wont drain or spin but will agitate
you have a bad lid switch. located under lid on left side of machine.
Dec 24, 2014 | Whirlpool Washing Machines
Machine wont drain
sounds like water pump is not operational or clogged
Nov 28, 2011 | Kenmore Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore 22422 Top Load Washer Logo
792 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
