Question about RCA OPAL M4001 MP3 Player
Power will not stay on
It is fully charged but will not stay on. it says hold no matter which button i push. it shows a lock next to the battery indicator that i have not noticed before.
I had the same problem. Then I noticed on the back of the player was a "lock" button. Once I turned it to unlock, the problem was solved.
Posted on Jan 29, 2009
I cant open
Push the power switch up as far as it will go and see if the blue ring on the front of the player lights up.
The Fuze's power button is not a traditional button but a slider, so if you did not push the slider up all the way, this may be the only reason it was not powering on.
Reset the Fuze by pushing up on the power switch and holding it in the up position for 10 seconds.
Try to power on the Fuze again after it has fully rebooted.
Connect the Fuze's USB cord from the Fuze to a USB port on your computer.
You should see a yellow charging light illuminate and the battery symbol blinking on the Fuze's main display.
Once the battery stops flashing, the Fuze is fully charged and you can try to power it on again.
hope this helps
Sep 27, 2012 | SanDisk Sansa Fuze MP3 Player
New Bigfoot toy for XMAS buzzes three times and stops working. Reset with power switch and does the same thing repeatedly. Made sure battery was fully charged.
There is a pen hole beside power switch........with the power off press and hold this button (with a safety pen or something)....while holding the button turn it on and hold the button for at least 3 seconds. Then push every button on the remote, then charge the battery until the indicator is "green". That will fully reset your Bigfoot.
Jan 02, 2011 | Mattel Fisher-Price Imaginext Big Foot
My SANSA e260 froze up. I can't shut it off. Has a blank screen was trying to charge it.
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player. NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 03, 2010 | SanDisk Sansa e260 MP3 Player
It froze up
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary. To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Or try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e260 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
My sandisk sansa clip 1gb wont turn on
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
My samsung p2 will not turn on...
battery can fully charged but if contacts of the tray are dirt than no current can pass through. firstly check contacts, switch showing that it is come out, after pushing it in, also check for polirities of batteries.
Mar 25, 2009 | Samsung YP-K3 MP3 Player
Will not power on
also make sure the lock switch on the right had side of the unit is not locked.
Cold reset the handset - will lose any unsaved data - hold power button, right hand scan button and reset button on the back at the same time
Jan 03, 2009 | Symbol MC50 Pocket PC
RCA OPAL M4001 MP3 Player Logo
48 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
