Question about NEC MultiSync 77F 17 in.CRT Conventional Monitor
NEC 77F CRT monitor - displays alternating black \ white crosses
When the monitor is powered on, it shows two perpendicular white lines that intersect the center of the screen on a black background. After 2 - 3 seconds, it shows black lines on a white background. It alternates from one to the other continuously, and I can't get it to do anything else (OSD controls make no difference.) NEC has a monitor troubleshooting guide, but I haven't been able to access it. I'm hoping the CRT is still good and that I can keep the monitor out of the landfill - what do you think's wrong with it?
  • Anonymous Jul 20, 2007
    I didn't think any of the buttons were stuck, but I pushed all of the buttons on and off (with the monitor turned off), and I connected the monitor to a dual-monitor setup. I was thinking that maybe I could get the monitor unstuck if I could change the resolution (or something like that.)
    The monitor worked perfectly as soon as it was powered on, so maybe it was one of the buttons. Thanks for the suggestion AKAShadow, it seems to have worked.
  • Anonymous Apr 08, 2009
    I have 2 pendicular lines intersect middle of my screen and it does make a beeping noise
  • 32 Answers
Sounds like its stuck in test mode. Make sure that none of the buttons are stuck in place and does it make any noise while its turned on?
Posted on Jul 19, 2007
SOURCE:
What is the meaning of perpendicular lines
Parallel lines are lines that go on forever and never cross. In mathematics terms, they have the same slope, but different y-intercepts. For example, y= 3x + 5 and y=3x +7 are parallel lines.
Perpendicular lines are lines that intersect each other at 90 degrees or at right angles. If y=5 and we are looking for a line that intersects it at 90 degrees (or right angles), the line would be x= 4.
Another example would be y = x. The perpendicular line would be y = -x.
To find the perpendicular line, the slope will be the negative reciprocal. For example, y = 3x + 5, the line perpendicular would be y = - 1/3 x + b.
Another way of looking at this is if you take the slopes of the two line and multiply them, you should get -1.
Let me know if you have any questions.
Good luck.
Paul
Jan 26, 2016 | Office Equipment & Supplies
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
Fe991sb
Usually you just pry them apart. The cracking sounds and the amount of force necessary to do this is sometimes unnerving to the inexperienced.
Mar 30, 2013 | NEC-Mitsubishi NEC Display Solutions...
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 09, 2012 | Acer Aspire One D255-2670
Getting black horizontal lines across the screen. It started off as an intermittent problem, now occurring more often. I changed the video card and the power supply tests fine and I changed the refresh...
I would test the cable, use it on a different monitor or try a different cable. That is the only other thing to check, otherwise it definitely is the monitor.
Apr 07, 2010 | NEC AccuSync 700 (White) 17 in.CRT...
Laptop Monitor shows balck and white stripes
From what i can barely see it your photo it looks like your video chip  (which is part of the motherboard's chipset) has died. It will be expensive to replace the motherboard.
To recover all your data is easy - just remove the hard disk from the laptop, put it in a case like one of these
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010010092%201053807124%201054107131&name=SATA
then connect the case to another pc.
Mar 26, 2010 | Toshiba Satellite A105-S4084 Notebook
CRT Monitor power led is green then becomes yellow. The monitor is blank or black. Pls. help.
Signal from Pc is weak and may indficate a failing video card or a loose connection
Aug 02, 2009 | NEC MultiSync FE700M (White) 17" CRT...
Icons and everything displayed sideways
If you're referring to the taskbar that's usually on the bottom of the desktop, click on the taskbar and drag it to the bottom. Then right click on the taskbar and check "Lock the taskbar". This should solve your problem. All the best.
Greg
Jun 23, 2009 | NEC MultiSync 77F 17 in.CRT Conventional...
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
NEC MultiSync 77F 17 in.CRT Conventional Monitor Logo
196 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
