Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
Digi002 faders go down when i open session
When i open a session all the faders go to their positions then it says validating then all my faders go down. I thought it was my firewire cord so i went and bout a new one, but its like it loses connection or something.  please help
Dude.  This is a known problem with the Digi 002 units.  It has a problem with the power harness - which distributes the power to the faders etc.  It's happening to mine as I type.  If your unit is registered, get in touch with your local DD support and let them know.  They'll send out a new harness, instructions on how to install it and contact cleaner - free of charge - after warranty service - due to the fact it's a known problem.
If you can't register your unit for some reason, the gear to buy is around the $70US mark - which I didn't think was too much to get my system up and running again.
Posted on Mar 05, 2009
Where can we buy this power harness? link please
Posted on Jul 28, 2009
Travelpilot fx fader
Open the fuse panel and remove each fuse while the radio is playing. The ignition key is in "ACC on" to ascertain which fuse connects to the T_Pilot. Make a note when you've identified which fuse is the T-Pilot's circuit. Replace each to original position after 30 seconds. By removing the fuse, you disconnected all power to the Travel Pilot. When you replaced the fuse, there will be a delay as the Travel Pilot reboots itself, maybe 2 to 5 minutes. If its fully functional again, then it was a software glitch Ford deliberately programmed to psyche you into trading-in your old Ford and upgrading to a newer model.
Nov 29, 2013 | Cars & Trucks
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
I cant open my pokerist.com account... its says invalid email/password but before i used to open it my account email on pokerist.com is christinebbbbb3@yap.com chips 1.7b.
Have you not checked the website for help in acessing your account there normaly have a password or username recovery in place if not contact them via email or telephone.
hope this helps
Mar 27, 2011 | Kama Games The Pokerist club — Texas Poker
Crest Audio Console Fader Distortion
Change your fader. Because your fader had some problem like funges or corbun pealed up. so try to change.
sampath india
Feb 23, 2009 | Capcom Demon's Crest for Super Nintendo
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
The main bus on my behringer 2222 mixer has gone. nothing patched to the main bus comes up on the main vu meter, and only a feint distorted noise comes out of the headhones when the main bus is turned up...
please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Aug 17, 2008 | Audio Players & Recorders
My microphone has a pink plug for the mic and a green one for the headphones and i plugged them in and they didnt work but they worked once before
apply a lubricant contact cleaner in the sockets(the place which you put your plugs)and insert plugs in and out many times-
right click in speaker icon and open volume control and check there is no mute mark in all faders-and faders in up position.
Jul 22, 2008 | Audio Players & Recorders
There is no audio sound installed on my laptop... there is no sounds coming from the laptop?
check sound driver and reinstall it again-right click in speaker icon and open volume control confirm that there is no mute in all faders and fader level in good level(up position)-try various sound files(songs-music-films-dvd).
Jul 18, 2008 | Audio Players & Recorders
Pc speakers will not play on my computer
1-confirm that you put it in right place(almost green socket).
2-right click in speaker icon and open volume control.
3-confirm that volume control fader is in up position and not muted.
4-check all faders are up and not muted.
5-you must confirm first that your speaker is ok first(try with another speaker)
Jul 04, 2008 | Audio Players & Recorders
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
625 people viewed this question
Top Digi Computers & Internet Experts
doggzzz
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
