Question about Tempest Pool & Spa
Control panel is unresponsive on tempest spa - Tempest Pool & Spa
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 52 Answers
What model control box is under the spa? If we know that we can match up the correct replacement control panel.
email me: rod@uspartscenter.com
Rod
www.uspartscenter.com
Posted on Feb 01, 2013
How to replace air controller topside
If you need to replace the control panel altogether, there are a few things you should know beforehand. Before you purchase a new panel, make sure it's compatible with your existing spa control pack. There is often a part number on the existing top side panel when you pull it out of the housing. A sticker is typically on the side indicating a part number from the manufacturer. Otherwise, get the number for your spa control pack and call the manufacturer to find out which top side panel will work for you.
Replacing a topside control panel is a fairly simple process. First, turn off the power to the unit. Remove the spa access panel and take the cover off of the control box and unplug the wire that goes form the topside panel to the circuit board. Gently remove the topside control panel. Remove the plastic from the self-stick backing of the topside controller. Place the topside controller in the place of the previous one. Plug in the topside wire to the circuit board and power back up the spa to test the function of the new unit.
Mar 31, 2017 | Pool & Spa
Looking for suppliers for tempest computers
What is you location ?
Search the internet under 'Tempest computers'
18.December.2014
Sep 10, 2014 | Computers & Internet
Wiring diagram for BlueRidge Spa
The wiring diagram for each spa is located on the inside panel of the control box.
Remove the side panel of your spa where the control box is located which is usually on the same side where the topside button is.
Once you remove the side panel you will see the control box.
Remove the front cover and on the inside of this cover is where the electrical diagram for all the wiring is found.
Rod
US Parts Center
Nov 02, 2013 | Pool & Spa
How do I unlock the control panel on my spa?
Here's a link to a list of ways to unlock the control: http://spapartsshop.blogspot.com/2012/02/spa-control-panel-unlock-codes.html
Those guys should be able to help.
Nov 25, 2012 | Hydro Quip Inc Pool & Spa
MVP V Model CMV1000ADW
From the description it is the keypad control board problem, membrane "shorts" replacement only option.
Apr 04, 2012 | Maytag Appliances Over-the-Range Microwave...
Tempest 170- Skeg is stuck in the skeg box. The slider used to control the skeg when pulled back to put the skeg down will automatically slide forward to abaout half-way again. What do you think the...
You need a repair kit from wilderness systems.I had the same problem. It happens when something gets stuckbetween the skeg and the skeg box, the first think most of people do is to force the lever and doing so make the cable bent and after that it would never work again.They sent me the repair kit with no charge and now everything is working fine.
Jul 29, 2011 | Wilderness Systems Tempest 170 Kayak with...
Control panel unresponsive
open up the inner door shell after powering down the unit from the power source,wiggle and remove and replace all ribbon cable connections on the electronic control panels and any other connections you can see,moisture corrodes these connections after years and removing and re-installing these will sometimes wipe off any corrosion for a better connection to the machine the screws are on the inside of the door to access the control panel
Jun 19, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
43 people viewed this question
Top Tempest Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Tempest Pool and Spa Expert? Answer questions, earn points and help others
