Question about Toshiba TLP-X2500 LCD Projector
Indicate the fan icon on screen and flash temp red bulb on projector and automatically off the projector
5 Suggested Answers
SOURCE: toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Posted on Nov 12, 2009
  • 6 Answers
SOURCE: I have a Toshiba TLP 260 Multimedia Projector
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Posted on Apr 21, 2010
  • 699 Answers
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 18, 2011
  • 6694 Answers
SOURCE: We have Toshiba TDP-T05 projector - recently
Before going to by a new one just try to do the following
First of all try to reset the lamp hour of your projector. For resetting the lamp hour do the following.
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on,
Otherwise Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projecto and watch.
Posted on Mar 07, 2011
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
Dec 05, 2016 | Office Equipment & Supplies
When its turned on blinks red about every 2 seconds dark screen
It is probably the projector bulb. The two red blinking lights indicate bulb failure. Replace the bulb and also thoroughly clean the cooling fan and vents to prevent future overheating which can shorten bulb life.
Hope this helps.
Oct 02, 2015 | Office Equipment & Supplies
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
What should i do when my projector's temperature light is flashing red 30 sec after start up?
try changing the light bulb. they have a time limit on them. with mine, I had to change the light bulb. Not cheap, but it worked for me.
Nov 12, 2014 | Epson PowerLite Home Cinema 8350 3LCD...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
Feb 21, 2009 | Epson (V13H010L34) Projector Lamp for...
Toshiba TLP-X2500 LCD Projector Logo
47 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
