Question about Bosch 24 in. SHV66A03 Built-in Dishwasher
Dishwasher When the dishwasher runs you hear a ticking noise. It is a Bosch SHV66A03 Undercounter, Electronic dishwasher. Any ideas on what would cause the ticking????
  • Louis Collins Jul 20, 2007
    The sound is in the lower section, close to the floor and the dishes are not getting clean. I believe you might be right about something being caught in the impeller. I will try to investigate. Any other ideas????
    Novelist:
  • 159 Answers
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Posted on Jul 19, 2007
6ya staff
SOURCE:
Dimensions of Bosch SHV66A
as you have the machine in front of you, take a tape measure and measure it
Jul 22, 2015 | Bosch 24 in. SHV66A03 Built-in Dishwasher
The soap dispenser isn't opening when we run it.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 13, 2011 | Bosch 24 in. SHV66A03 Built-in Dishwasher
My dishwasher computer is not resetting. It apprears to be stuck in a cycle. is there a way to reset it?
The Cycle is due to a process some Cyclic ~ Redundancy,...loL...:) Confused Computer Processes. Try to Unplug it completely from the Power Source. Leave it a while, turn it on while unplugged for a bit of time, like 2 minutes, turn if off, plug it back in. And try running it again. :)
Apr 02, 2010 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Unable to turn off the delay start and the latch is in the wrong position so that the door will not close properly. Also, there is no digital display--it remains dark. I tried the cancel/drain, which...
Pull the open handle to open the latch up and try to get it to close. Disconnect the power to the machine for a few minutes. Run a cycle that you don't usually run. See if that helps.
Nov 02, 2009 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Is there a reset button on Bosch undercounter dishwashers?
yes press drain and cancell for 2 min.this will cancell operations
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Very long cycle time for Bosch DW
There is a recall on the control board of many of these models, butyour problem is likely not related. I have written a guide to help. It is here. Thanks!
Jan 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Jan 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHV66A03 Built-in Dishwasher Logo
427 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
