Question about Maytag 24 in. MDB9150A Built-in Dishwasher
No water comes in to wash dishes.
Where is the water valve inlet located on my Maytag MDB-9 diswasher?
  • 142 Answers
Sorry to sound obvious, but you will have pull the dishwasher out to get to it, just follow the hose into the inlet valve unit, they are located under the unit at the back.
Posted on Jan 27, 2009
Dishes not coming clean
Check water inlet valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
How to test a dishwasher water inlet valve.
How to replace a dishwasher water inlet valve.
May 26, 2011 | Maytag Dishwashers
I started a load of wash and the water stopped flowing into the machine. It will spin, so it isn't anything electrical. The water will not fill it up?
If there's no water at all, make these checks: If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 06, 2011 | Maytag Washing Machines
NF appears in the screen when trying to wash with warm water
NF--No Fill
Is there water getting to the machine?
Jan 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do I find and remove the water inlet valve in a Maytag MDB-9 dishwasher?
CLICK HERE for a representation of the part in question.
CLICK HERE for an expanded parts diagram (#1)
1. Shut off the water and remove the lower access/kick panels.
2. Then disconnect the two wires from the inlet valve terminals - note which one goes to which terminal
3. Using an open end wrench loosen and disconnect the water supply line.
4. Remove the two screws securing the valve assembly to the inside wall of the dishwasher
5. Loosen the clamp on the water outlet line and slide off the hose.
Installation is pretty much the same in reverse.
Sometimes the valve assembly comes with the wire terminals oriented in a different direction than what you may find when you take yours off. If it won't work for you, remove the four screws that hold the electrical side of the inlet valve and rotate it to the needed position.
Make sure when putting it back together that you tighten the screws evenly to prevent leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2010 | Maytag 24 in. MDB9150A Built-in Dishwasher
The dishwasher will not fill with water what can i
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Apr 13, 2010 | Maytag 24 in. MDC5100A Free-standing...
My maytag dishwasher does not have enough pressure to drive the water through the wands onto the dishes. I have cleaned the screen underneath the bottom wand but this has not increased the pressure enough....
I would check to see if you have enough water in the dishwasher. Let the dishwasher fill with water and set the spray arm in a positoin you will remember where it is.
Take a large pot of hot water and add it to the dishwasher and close the door. Start the dishwasher and observe to see if the spray arm moves.
If it moves you may have to change the water inlet valve. It may be restristing the water flow into the dishwasher.
The water inlet valve is located behind the lower kick panel.(4) screws, Remove the panel and see where the water pipe hooks into the water inlet valve. Remove two wires and two screws. Shut water off and remove the water line going into the valve and the small rubber hose coming out of the valve.
Replace valve and reinstall kick panel.
Hope this helps.
Dec 31, 2009 | Washing Machines
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Maytag top loader washing machine stooped pumping water out
    HI
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • Thank you
    Dec 07, 2008 | Washing Machines
    Dishes not clean
    If your dishwasher is cleaning poorly, check these:
    Water-inlet valve
    Internal filters
    Drain valve
    Spray arms
    Water temperature
    Detergent cup
    Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
    When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
    Dishwasher Water Inlet Valve Replacement
    Be sure to read and understand any instructions that come with the new water inlet valve.
    Tools required:
    Adjustable wrench
    Multi-Screwdriver
    Pliers
    Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    Maytag 24 in. MDB9150A Built-in Dishwasher Logo
    177 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
