Question about LG DLGX3471W 7.3 Cu. Ft. Ultra Large Capacity Gas Dryer with Dual LED
MY LG DLGX3471W DRYER CHECK FILTER LIGHT IS ON AT BEGGINGING OF EACH CYCLE
jgwhomeequip
  • 1902 Answers
SOURCE: LG dryer check filter light
Have you checked the lint trap? If not this is what it is talking about. If you have then you should check your dryer vent line. Your lint trap should be on the inside of the dryer. If you need more help let me know. Also if you unplug the unit after checking what I said and the light still is one. Unplug it for 1 minute then plug back in this should reset everything
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
SOURCE: LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
This gives you what you need.
http://136.166.4.200/contents/Laundry/DLE2532/DLE2532_Service_Manual.pdf
Posted on Nov 11, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have an lg dryer model DLG5966W and the check
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Posted on Jun 17, 2010
Gas lg steam dryer DLGX7188RM cleaned filter , vent tubing, unplugged, still check filter light flashing , hit power goes straight to cool down .
the check filter light is just a reminder. it is not connected to a sensor. goes out when you start the next cycle so your issue is not connected to that.
May 30, 2016 | LG Dryers
CHECK FILTER LIGHT COMES ON UNTIL I START DRYER
The CHECK FILTER light will appear between every cycle, simply as a reminder to clear the lint filter before starting a new load. If the unit runs properly, then this is no cause for concern. If it will not start, then the unit may require service.
Oct 28, 2012 | LG DLE5977 Electric Dryer
CHECK FILTER LIGHT IS ON UNTIL I START DRYER THAN GOES OFF
Oct 28, 2012 | LG DLE2514 Electric Dryer
Model: LG Steam Dryers DLEX2501R Problem: Shows "Check Filter", while dryer still does the job
do you mean a condenser dryer?, as steam is water doesn't dry anything to well, if it is a condenser dryer the check filter or clean filter light should always come on towards the end of the cycle (varies between models some have both clean filter and empty tank lights on at end of cycle just as a reminder to do so and some don't have any lights), it is simply a reminder for you to clean the filter after each use unless this is something that has only just recently happened
Apr 17, 2011 | LG DLE2514 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dryer is overheating and check filter light is on
Check filter light comes on after everycyle.....run unit on an air dry cycle and check your vent from the house to the outside....might be clogged. be sure you are cleaning you lint trap every use.
Jun 10, 2009 | LG DLE0332 Gas Dryer
Owners manual
The "check filter" light comes on just when I start the drying cycle the light goes away but the "Cooling" light comes on and stays on throughout the drying cycle, clothes stay damp thus a second drying cycle. Due to this annoying problem with my LGDLE2512W my laundry time has doubled, taking over 3 hours and a high gas bill just for a medium size load of laundry....
Aurora Tracy
Sparks, NV
May 20, 2008 | LG DLE2512W Electric Dryer
LG DLGX3471W 7.3 Cu. Ft. Ultra Large Capacity Gas Dryer with Dual LED Logo
71 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
