Question about GE Profile JB968 Electric Kitchen Range
Range problem The bake probe keeps flashing. No probe inserted.
  • ErickMikiten Jul 19, 2008
    I pulled out the probe connector, and it looks to be in good shape - no grounding against the oven wall.
  • ozzibear Nov 13, 2008
    I have the same issue, the probe light flashes, we have never used the probe. When we turn on the oven,, then probe light flashes and beeps until the oven reaches the desired temperature, very annoying.
    Novelist:
  • 159 Answers
The control bord may be bad or the receptical where the probe connects may be bad and grounding out agenst the body of the oven. I would remove the plug and make sure the wires are good and its not grounding out. If it checks out ok replacement of the control bord should solve the problem
Posted on Jul 19, 2007
2 Suggested Answers
  • 61 Answers
SOURCE: Electric range displays bake probe
if you need a parts check out appliance parts solutions
Posted on Feb 10, 2010
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Range over heats and flashes error code f3-e2 Whirlpool
That is a bake range over tempature error. First try disconnecting the power to the range for more than 10 minutes and see if the error re-appears. If it does then you will need to test the tempature probe with an ohm meter. At room tempature the probe should test 1000 to 1100 ohms. If you get a reading that is out of range or different ohms than rated replace the probe. If the probe tests good then replace the control.
Jan 17, 2010 | Whirlpool Ovens
Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
Nov 26, 2009 | Ovens
My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Sep 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
May 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
Meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
GE Profile JB968 Electric Kitchen Range Logo
592 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
