Question about Panasonic Lands Phones
Manejo del telefono KX-TCM415MXB
MANUAL TELEFONO PANASONIC MODELO KX-TCM415MXB
4 Suggested Answers
SOURCE: necesito el manual del usuario
Necesito el manual del usuario en español para el telefono inalombrico vtech CS5121
Posted on Oct 29, 2010
bbl242003
  • 1637 Answers
SOURCE: manual telefono panasonic kx-tg2258 en
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 18, 2011
SOURCE: necesito el manual del telefono
necesito el istructivo del telefono inalambrico del modelo vetch 5.8 GHzme lo podian publicar porfavor
Posted on Jul 17, 2011
Mi telefono inalambrico no tiene volumen
Por favor proporcioneme su n?mero de modelo para que poder ayudarle.
May 31, 2015 | Uniden Cordless Phone
COMO DESBLOQUEAR TELEFONO PANASONIC
Hola!, si miras en el telefono, si te fijas hay un boton redondo como debajo de la pantalla y lo presionas por aproximadamente 2 segundos se desbloqueara. Buena Suerte!
Jan 13, 2014 | Panasonic Lands Phones
MI TELEFONO REQUIERE ALGO QUE DICE EN LA PANTALLA "NIP" QUE HAGO ??
Hola, creo que a lo que se refiere NIP es Numero de Identificacion Personal, es mas conocido por su abreviatura en Ingles PIN, puede ser el PIN del telefono o del SIM card (llamado comunmente CHIP), si es el PIN del SIM card usualmente el operador pone cuatro ceros, si es el del telefono habria que buscar en el manual del mismo cual es de fabrica (default).
Mar 02, 2011 | Computers & Internet
Hola el problema es que son dos telefonos registrados en una base pero el 2 que seria el movil no funciona no da linea suena como si estuviera ocupado,ya lo intente con el manual y nada ha es nuevo gracias...
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Feb 28, 2011 | Philips CD1503B/17 Phone
En la pantalla del telefono dice linea en uso
my house phone says in use what can i do to fix it
Dec 05, 2010 | Panasonic KX-TG5632 Phone
Necesito el manual del telefono inalambrico vtech 5.8GHz modelo:CS5211
Nov 19, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
Necesito el manual del usuario en español del telefono vtech cs5121
Aug 10, 2010 | Vtech CS5121-3 Trio Cordless Phone
How can i get my nokia 5220 to work as a webcam
puedes usar el: Mobiola Web Cam For XXXX (XXXX es el modelo del telefono)
saludos compañeros, desde uruguay
x.lautaro@hotmail.com (software an web design)
you can use: Mobiola Web Cam For XXXX (XXXX is the model)
Jul 02, 2009 | Nokia 5220 XpressMusic Cellular Phone
Identificador de llamadas
Yo no conozco ese producto, pero te puedo ayudar si me identificas el manufacturero (fabricante) y el detalle del modelo. Es posible que ese manufacturero tenga instrucciones en espa?ol. Si no, puedo hacer la traducci?n al ingl?s. Estoy en Puerto Rico y soy bilingue,
Mar 26, 2017 | ATS 4121CCL Twin Cordless Phone
Telefono inalambrico kx-tg3031s
you may coldsolder the flash ic and cpu
May 28, 2008 | Panasonic KX-TG3031S Cordless Phone
Lands Phones Logo
85 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
