Question about Dell Augmentix XTG630 PC Notebook
Turning red screen lights on
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
Inspiron mini 1018 blank screen with light behind, loud beeps, strange smell
I have green screen solution where now it changed to whole black screen with some red line and produce a sound like TV Signal..I don't know everthings about repair my netbook..What should i do?
May 29, 2012 | Dell Inspiron 1018 Notebook
Red and yellow line across the screen.
From the description the LCD screen will need to be replaced, first! hook a spare monitor to the video output on the back, if picture okay! the problem is the above mentioned, but if both screens show the same symptom it is the video graphics card.
Apr 19, 2012 | Dell XPS M1530 laptop, Crimson RED, 15.4"...
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
Display works but there is no light.when i turn on the notebook light turns on few seconds and then turn off.dell latitude 110 l.
connect an external laptop screen to inverter leaving the display nap on the laptops original screen.if the external screen lights up and off then replace the inverter.if not then the bulb in the dell laptop screen needs to be replaced.contact me for more info tel.75376764
Jun 22, 2010 | Dell Latitude 110L Notebook
How do i turn off the red light on my dell laptop
buy a new battery or remove your battery from the laptop.
The red light is signaling that the battery doesnt
respond to charging.
This is the solution. Please vote
Jan 14, 2010 | Dell Latitude D600 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Dell loptop wont turn on
take out ur batteries, clean the terminals with spirit or light alcohol, then re-insert it. better u use direct power supply but be sure to check that the power is beig supplied and the terminals/sockets are cleaned.
did this helped u. if not, tell me, when u push the power on button of ur notebook, does anything happens, like the fans start spinning or light went on. does the screen turn on or does something appears on the screen?
if nothing is happenng after pressing the power button, then this is a clear case of problem with ur power recieving section of the notebook. go to your pc dealer.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
Dell Augmentix XTG630  PC Notebook Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
