Computer will not shut down
I am running Windows XP updated, and have gone to ''control Pannel'' to set the power options as follows: ''power scheme''' - Home / office > Turn off monitor - 1 hour > Turn off Hard Drive - 1 hour > System standby - 1 hour > System Hibernates- 2 hours, and clicked OK but my computer stays on all the time it never shuts down! This is new as my computer used to hibernate at night.
  • mooburn Jan 27, 2009
    good idea but right clicking properities on desk top only brings me back to control pannel which was already set to times desired
  • 716 Answers
Right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Posted on Jan 27, 2009
My computer will shut down automatically..
your PC got a Dangerous Virus.
the Virus Shuts down or resets The PC in order to spread (in whole of the PC) more.
so download and install a new anti virus.(Like Nod32 or Norton etc)
then update it and run a full scan.
Jan 15, 2011 | Microsoft Windows XP Professional for PC
Computer re-starts when i want it to shut down or sleep
You should check to see if there is a setting time where the computer installs updates, because the computer may be updating at a certain time and then restarts to finish the update. Check the setting to you might also have the computer restart every so often. hope that this helps.
Jan 08, 2010 | Dell Inspiron 1525 Notebook
Upgraded mem.now mon pc dont shut off fan con to run
Computer doesn’t power down when users shut down
In some cases, Windows XP’s Setup program can misidentify the power management scheme in a computer’s BIOS as Advanced Power Management (APM) instead of Advanced Configuration Power Interface (ACPI). When this happens, users will notice that the computer no longer automatically powers down when they shut down Windows XP. Instead, they’ll see the message It Is Now Safe To Turn Off Your Computer and be forced to manually press the power button to turn off the computer.
You can verify this problem by checking the power management configuration in two places—Device Manager and the Control Panel. To quickly access Device Manager, select Start | Run, type Devmgmt.msc in the Open text box, and click OK. When you see the Device Manager window, locate and open the System Devices item. If Setup identified the system as having an APM-compliant BIOS, it will be listed as a Standard PC in the System Devices tree. (If it were identified as having an ACPI-compliant BIOS, you would see it listed here as a Microsoft ACPI-Compliant System.)
To check the power management configuration in the Control Panel, open the Control Panel from the Start menu. If the system is using Category View, select Performance And Maintenance and then click the Power Options icon. If the system is using Classic View, just click the Power Options icon. If Setup identified the system as having an APM-compliant BIOS, you’ll see an APM tab in the Power Options Properties dialog box. (If the system were identified as having an ACPI-compliant BIOS, you wouldn’t see an APM tab.)
You may be able to fix this problem with a BIOS update. To begin, check with the computer manufacturer’s Web site to see if it’s providing the latest BIOS update. If you’re troubleshooting an off-brand computer, you may be on your own as far as tracking down the BIOS update. Here’s how.
Once you obtain and install the BIOS update according to the manufacturer’s instructions, you must perform what I call a Refresh Installation, in which you reinstall Windows XP on top of an existing Windows XP installation. You must perform this reinstall operation because the power management features are tied to a special power management Hardware Abstraction Layer (HAL). During the Refresh Installation procedure, Setup will completely redetect all installed hardware, including the updated BIOS, and rebuild the power management HAL as well as the part of the registry in which information about the installed hardware is stored.
Jul 20, 2009 | Gateway M280E
I shut computer after windows updates and now it won't power up
1.Try booting into safe mode (F8 on startup) and then uninstall the update or you can run system restore. 2.try going to the advanced boot options and choose "Last known good configuration" 3.The last option is 'to do a repair install' if you have a Windows XP CD you can just do a repair of the OS.
Jul 16, 2009 | Acer Aspire L100 PC Desktop
My notebook shows it's running on AC power even when disconnected
Assuming you have a Windows machine suggest to check the Control Panel (Power Options / Power Options Properties / Power Schemes) to make sure the Portable / Laptop setting is selected. If your computer manufacturer has their own power management software installed on the notebook suggest to use it instead of the Windows software as it may have more specific controls for that machine. Make sure you have done all the updates and your notebook has the latest versions of any manufacturer software for power management for that model.
rongg
May 07, 2009 | Computers & Internet
Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
Computer Keeps Shutting Down
I found an article from Microsoft that may answer your question, which I have quoted below. The link to the page is
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/nostandby.mspx
Ifyour computer won't enter standby or hibernation, it may requireupdated drivers. Power management features, especially standby andhibernation, rely on device drivers that support power management inaddition to compatible hardware. Incompatible video drivers preventthese features from working. The built-in VGA driver, for example, is abare-bones driver that doesn't support power management.
If standby and hibernate don't work, install an updated driver for your display adapter.
Tip taken from Microsoft Windows XP Inside Out by Ed Bott and Carl Siechert. Published by Microsoft Press.
First check HPs website for updated drivers for your machine. Look at your drivers from the device manager and note the version numbers, then compare that with the version on the website.
If they are not helpful, you could try to manually update the drivers by finding them in the device manger, right click on each ACPI device (ACPI Lid, ACPI button, etc...) and select update driver.
If no updated ACPI drivers are available, check the power settings in the control panel. Under the 'Advanced' tab, there are options about what you want to happen when you close the lid, and when you press the power button. (Mine both say 'stand by'.)
To sum it all up:
  1. Check the power settings in the Control Panel /Check if it works
  2. Update Video Drivers /Check if it works
3. Update Motherboard and ACPI Drivers /Check if it worksReply with the results, then rate my solution. :)
Feb 21, 2009 | HP Computers & Internet
PC SHUTS DOWN MONITOR AND FAN
Hi Brandy19960,
Thanks for the posting in FIXYA.
Please do the following steps:
Step – 1
Right-click on My Computer, open Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” Uncheck the box in front of “Automatically restart.”
Step - 2
To change the setting, click Start --> Run--> type GPEDIT.MSC, click OK.
Drill down to Computer Configuration | Windows Settings | Security Settings | Local Policies | Security Options.
In the right pane, find “Shutdown: Clear Virtual Memory Pagefile.”
NOTE: Since someone actually has to have set this policy, the problem will be pretty rare, but is worth mentioning. However, Forum participant “roadrunner” reported that the personal security app Privacy Eraser automatically enables “Clear virtual memory pagefile,” and, therefore, may be the cause of a slow shutdown.
Step - 3
When Windows XP won’t powerdown automatically, the APM/NT Legacy Power Node may not be enabled. To enable this, right-click on the My Computer icon, click Properties | Hardware | Device Manager | View. Check the box labeled “Show Hidden Devices.” If it’s available on your computer, there will be a red X on the APM/NT Legacy Node. Try enabling it and see if this resolves the powerdown problem (Tip from Terri Stratton). Or, to check the other side of the APM/ACPI coin, open the Power Options applet in Control Panel. If there is an APM tab, make sure the “Enable Advanced Power Management Support” box is checked.
Step - 4
Try a Shutdown shortcut -
For a shortcut to RESTART Windows XP:
SHUTDOWN -r -t 01
For a shortcut to SHUT DOWN Windows XP:
SHUTDOWN -s -t 01
Step 5
WORK-AROUND: Disable power management for your USB hub: Open Device Manager (click Start, click Run, type DEVMGMT.MSC, click OK). Double-click to expand Universal Serial Bus Controllers. Double-click USB Root Hub. Click Power Management. Uncheck the box “Allow the computer to turn off this device to save power.” OK your way out
Step – 6
Click on the Start button.
Select Run from the menu.
In the run dialog box type “msconfig”.
Click OK.
Once in the msconfig utility select the startup tab. In the startup tab you will see several programs listed with a checkbox beside it. If there is a check mark beside the application listed, the application will startup when your computer starts up.
Regards
ELLIN
Sep 13, 2008 | Microsoft Windows XP Home Edition
No shutoff
Go to start>control panel>power options>advanced tab, then at bottom it should say shutdown when i press power off button.
Feb 19, 2007 | Jetway P400MTwin Motherboard
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
