Question about Dell Inspiron 1501 Notebook
Screen goes blank then makes a grinding noise then resumes
Everyonce in a while (once a day or so) my screen will just go blank, then the grinding noise starts for a minute or two, and the working swirly circle (the one that is like the former hourglass) appears then it all goes back to what I was doing. I do not have to restart or reboot. Should I be concerned?
  • woznickim Jan 27, 2009
    Thanks for the advice, I will make note of exactly what I am doing the next time it happens, but I can say that it does not come up with any error msgs, and I only use my laptop for internet and documents, spreadsheets, etc. I rarely use the cd/dvd drive. The grinding seems to come from the left side as opposed to the right where my cd/dvd loads. As soon as it happens again, I will post what programs I am using at the time. Thanks again
  • Celenous May 11, 2010
    Yes you should be concerned. Are there any error messages that come up before and or after? Have you identified any specific scenerios that cause the issue? Like you are burning a cd/dvd, watching a movie, etc. Can you identify where the noise is coming from the cd/rom perhaps? If it is still under warranty I would send it back to dell. Please try and capture or write down what happens the next time you hear the noise and or your screen goes blank. Note what you were doing before this happens, what programs were running,
I just ran a diagnostic tool on it and restarted
Posted on Jan 27, 2009
Loud grinding noise from under passanger seat.. comes and goes... hit a bump and it stops. hit another it starts. greased the u joints and quit for 3 days.. but back again. getting more freaqueant and...
If greasing the u-joints eliminated the noise for 3 days, that would be the first place to suspect. The grease will briefly remove most of the slack in the joint until it is slung out and the needle bearings will once again run dry & wobble. This noise can be anything from a grind to a loud squeal. I hope this helps.
Sep 27, 2011 | Cars & Trucks
Fuel pump making gurgling grinding noise on 1995 c1500
more then likely yes it is. I would just run your truck the way it is until it goes all the way bad. It may last a day it may last a year
Mar 19, 2010 | 1995 Chevrolet C1500
A buzzing noise everyonce in a while when clother
This could be simply your end of cycle signal that goes off. but if your hearing this while your clothes are drying, depending on where your hearing this buzzing it could be possibly something stuck inside your blower fan and is now rubbing up against it. this usually can be seen once the front panel is removed. It could also be your timer depending on where your hearing it from. a lot of older units will have a noisy timer motor, even though the timer itself will be okay. hope this helps.
Thanks
Oct 14, 2009 | Kenmore Dryers
Switch printer on,just get grinding noise on right hand
try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Nov 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Dryer Making a Grinding Noise
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Feb 01, 2008 | Kenmore 63942 Dryer
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
It is stuck!!
When changing the hdd it must be paired with the DVD player using the Service Remote Controller to be found only at Authorised Pioneer Service Centres.
Mar 17, 2017 | Canon BJC S800 InkJet Printer
Dell Inspiron 1501 Notebook Logo
141 people viewed this question
Alun Cox
