Question about Westinghouse Microwave Ovens
INSTALLATION OF WESTINGHOUSE OVEN POR663S
REQUIRE WATTAGE FOR INSTALLATION
What is the wattage for the white westinghouse microwave model wmw 17778
Open your microwave door and look on the top or bottom, it should be on a sticker.
May 11, 2017 | Westinghouse Microwave Ovens
What is the wattage
There are 2 different wattage's on a microwave oven.
1 The wattage a microwave oven uses from your wallsocket that is in a range from 1500 watt to 2500 watt. you can read this on the typeshield on the back of the oven.
2 The wattage the oven put in you food. ( that is also the wattage that a foodpackage or recepy mentions. it is normal in the range from 600 to 1200 watt. you have too lookup this in the manual or manufacturers website.
Mar 03, 2015 | Microwave Ovens
What is wattage of westinghouse touchn set microwave oven
wattage has nothing to do with physical size measure it with a tape measure and go buy one that size or just a tad smaller .
Oct 13, 2014 | Westinghouse Microwave Ovens
Looking for the wattage on a Westinghouse microwave
Hi Bart,
As far as I know the serial will not help,
If you reached the label on the back with the serial
you should see there also the mode.
And maybe aslo details on the microwave like the wattage.
Jan 11, 2014 | Westinghouse Microwave Ovens
Does not bake items within the time frames outlined in recipies at a prescribed temperature.
Check the times against the wattage of your oven.
Quite often the wattage for heating times are higher than the wattage of your oven.
Oct 29, 2013 | Microwave Ovens
How many watts are on the wst3501 microwave oven?
Westinghouse WST3501 Microwave Oven 0.7 model or 700 watt
Good luck (remember to rate this answer).
Apr 08, 2011 | Westinghouse WST3501 Microwave Oven
I need to install this range in a new kitchen and need to know the electical specs of the supply power
I don't see what range you're referencing. I see a title of microwave ovens. But, in any event, here's circuit requirement for each.
If it's a cooktop range: 220 volt 30 amp dedicated circuit
If it's a microwave: 110 volt 15 amp dedicated circuit
Charlie
Aug 22, 2009 | Microwave Ovens
Wattage
Look on the back for the power requirements, them muliply the number of amps drawn times 100 . example 10 amps times 100 = approx 1000 watts, that will give you an approx. wattage. hope this helps
budman630
May 12, 2008 | Microwave Ovens
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
