XP Computer Standby Feature Question
Ever since I added a linksys router to my computer, the standby feature stopped working. I have it set to sleep at 20 minutes of idle time. The monitor still sleeps at 15 minutes with no problem, but the pc will not go into sleep mode. what could cause this.
  • 585 Answers
Have you disabled "Wake on LAN" in the power settings? There are also other settings in Power management that could affect this.
There should also be general settings for power savings such as "none" "medium" and "maximum power savings" With a little explanation of each.
Posted on Jan 27, 2009
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Tip
Windows Vista : System not coming up from Sleep Mode.
Disable Hybrid Sleep Mode in Windows Vista Windows Vista has a neat new feature for laptops called “hybrid sleep”. Actually, Windows Vista has a neat new feature for laptops called sleep too, so I’m getting ahead of myself a bit.
Windows used to have a fairly simple hardware suspend command called “standby”. However, this operation took a while to execute (both entering and exiting standby) and it was somewhat unreliable when performed repeatedly, on certain hardware or with certain applications running. Sleep is meant to alleviate these problems by just serializing the current state into memory and then shutting down all devices other than the RAM. With the OS state simmering in memory like that, entering and exiting sleep is nearly instantaneous. However, the dark side to all this is if there is a power outage while the computer is in sleep, all of the unsaved data is lost (since it just existed in memory). That’s where hybrid sleep comes in.
Hybrid sleep saves the OS state into RAM, but it also writes it all to the hard drive as well (sort of like hibernate does). This ensures that even if power is lost, the data will remain. This all sounds like a good idea, but in practice it’s just as slow as standby was.
Now, laptops have batteries and most of them are configured to enter hibernate when the battery dips below a certain level. This means that unless the battery is physically removed, power to the RAM is never unexpectedly cut. Thus, we don’t really need the hybrid sleep feature. Unfortunately, giving hybrid sleep the pink slip is a little harder than it could be.
Step one, open up the power options setting from the control panel and select the “Change plan settings” link below the selected power plan.
Once in the resulting dialog, choose “Change advanced power settings”. Now you need to scroll through the miles and miles of options to find the “Sleep” node. Expand this, and then the “Allow hybrid sleep” node below it. You should see two options, “On battery” and “Plugged in”. Set both of these to “Off”.
Once this is done, click “OK” and you should be all set! From now on, whenever your laptop would normally go into “Sleep” – usually when the lid is closed or when inactive for a certain time – it will enter full sleep mode, rather than hybrid sleep. And when you go to awaken it from its slumbers, it should be fully responsive within a second or two of reactivation – as opposed to the 10-15 seconds after hybrid sleep.
on May 28, 2010 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
Jul 08, 2011 | Uniden CEZAI998 Phone
When i shut down my pc it shuts down, but the psu stays on, i can turn it off by the button but not by the desktop, any ideas???
Hi, "Sleep" mode or "standby" mode allows your computer to go on standby or sleep until you "wake" it up again. This is a power saving feature which is usually used for a few hours. You can change it to completely shut down everything (including power supply) in power supply options in your control panel. Check out your help section for sleep or standby options. Hank
Aug 27, 2010 | Dell Dimension E520 PC Desktop
After i touched the reserved button, the router stopped working.
Did you press the Reset button on the router ?
If you press the reset button then the router will come back to the factory default settings. You will need to reconfigure the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 24, 2010 | Linksys WRT300N Wireless Router
Problems with system going to sleep. How to turn
Power options in control panel is where you can alter the settings for sleep, standby and hibernation.
Mar 30, 2010 | Western Digital My Book World Edition II 2...
How do i stop the monitor going to standby or sleep while watchin movies every so often?
Vista: "Control Panel"-->"Power Options". On the left hand side you will see various options, you want the one labeled "Choose when to turn off the display". You will have 2 settings you can change, 1.Turn off the display and 2. Put the computer to sleep. For both of those options, change them to "Never".
XP: "Control Panel"-->"Power Options". There will be a setting for "Turn Off Monitor", change it to never.
Feb 02, 2010 | Hannspree HW191D LCD Monitor
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
