Question about General Electric GE 11-in-1 USB 2.0 Card Reader & Writer - HO97949
General Electric GE 11-In-1 USB 2.0 Card Reader & Writer - HO97949 controller windows 7
Can the Kodak 50 IN 1 card reader be used as a USB to USB connection for tethering a tablet to a phone?
The perfect complement to any digital camera or cell phone! This 50-in-1 card reader is the perfect complement to any digital camera or cell phone that takes compact flash, secure digital, microSD, XD, or Memory Stick, MS PRO, or MS DUO cards. Simply plug the reader into your computer, put your card in the reader, and have full access to all your pictures and other files. It's that simple!
  • Universal Reader/Witer
  • High-speed USB 2.0
  • Mac OS and PC compatible
  • Compatible with all versions of SD/HC/MicroSD/CF/XD & MS/PROP Duo Reader/Writer
  • 1 year mfr. warranty
Compare with similar items
Would you like to give feedback on product content, images, or tell us about a lower price?
SPECIFICATIONS Flash Memory Card Product Type Reader Card Reader & Adapter Type Reader/Writer Card Reader & Adapter Interface USB Card Reader & Adapter Compatibility Mac & PC
Apr 29, 2015 | Kodak Cameras
It doesn t work with windows 7
it is defective. need new one. there are no drivers or anything...
Mar 29, 2014 | General Electric GE 11-in-1 USB 2.0 Card...
J1050 ge camera cannot see pictures in my computer
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 30, 2013 | General Electric GE J1050 Digital Camera
I have 3D Customizing and the newer reader/writer. The dongle works. The reader/writer is not found is what Customizing says. I have Windows 7 - any help will be greatly appreciated. Thank you.
3D will not run properly on a Windows 7 computer.The USB reader/writer will work fine with 5D software.
Trust me, I have tried extensively to get 3D to run on Windows 7. I ran it on Vista, for a while. Then an update to Windows ended that. I've never had it function normally on Windows 7.
Sep 12, 2011 | Husqvarna Viking 1
What driver do I use for Windows 7
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 18, 2011 | ID Tech Reader-Writer 3840 Magnetic Card...
TARGUS High Sped USB Memory Card Reader/Writer failure...
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 27, 2010 | Electronics - Others
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Details of acer extensa 4620 laptop
Here's a link to the manual. All the details you could ever need.
http://www.marriage-4u.com/files/notebooks/ex_4620_4620z_4220_user_guide_eng.pdf
Jan 14, 2010 | Acer Extensa 4620 Notebook
I'm running Windows XP, trying to connect camera to PC but PC doesn't recognize camera. How can I fix this?... GE A1250 camera
Take the memory card out and use a USB card reader to access your photos/videos. It's simpler and faster than connecting the camera itself.
Jan 05, 2010 | General Electric A1250 Digital Camera
Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Nov 19, 2009 | Electronics - Others
General Electric GE 11-in-1 USB 2.0 Card Reader & Writer - HO97949 Logo
83 people viewed this question
Top General Electric Computers & Internet Experts
David Payne
David Payne
Are you a General Electric Computer and Internet Expert? Answer questions, earn points and help others
