Question about Kenmore 95680 / 95681 / 95682 / 95684 Electric Kitchen Range
Kenmore smooth top range lt. 2 burners work right/cen do not work
4 years old convection oven smooth top. 5 stove top burners .  two burners on left function. 2 burners on right and center warming burner do not function.  indicator light comes on , no heat at burner.
  • premiermotor Feb 13, 2009
    I have the same problem, ours is a Frigidaire and just the front burner doesn't work. Did you ever figure it out?
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 219 Answers
SOURCE: Front right 8'' surface burner dose not light up period.
it could be your burner but most likely your infinite switch for that burner
Posted on Mar 25, 2009
heavyt15
  • 91 Answers
SOURCE: Kenmore range front left BIG burner will not work
Check infinite switch...110V one side 11ov other side
Posted on Aug 18, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
My Kenmore ultra bake stove model 665 75022101 now has a " Loc" code on the screen. The gas range doesn't work. How do I clear this?
Notice the 2 buttons at the top right, "top" and "oven". If the top burners won't initiate, press and hold for at least 5 seconds the "top" button to unlock it. If the oven won't work, press and hold the "oven" button for at least 5 seconds to unlock it. I hope this helps you!
Sep 15, 2015 | Kenmore Kitchen Ranges
Burners work, no display, no oven light, can't turn on oven, buttons don't function
Check your circuit breakers, they should be double breakers. Probably 30 to 50 AMP. Sometimes one side of a double breaker will trip or fail. This will give the appliance 120 volts instead of 220. The "leg" of the 220 volt circuit that is out might control the stove's display, and the oven would not work on 120 volts. If the burners aren't as hot as they should be, or are slow in heating up it would also indicate a faulty breaker If it's not the breakers it's likely a problem in the stove circuitry.
Dec 09, 2014 | Kitchen Ranges
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Yesterday I heard a loud pop from inside the stove. Frigidaire smooth top professional series just about 5 years old. Looked inside and my parchment paper had caught on fire which had never happned before...
Is this an oven or the cook top?
A blown oven element is possible. You may still be able to bake but the oven will seem to take forever to warm up. An easy check would be to crank the heat up full bore and put your hand near the top then the bottom. You should feel more intense heat the nearer you get to a working element.
May 08, 2009 | Kitchen Ranges
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Kenmore 95680 / 95681 / 95682 / 95684 Electric Kitchen Range Logo
163 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
