Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
How do I hook up 6 volt batteries on 806 farmall diesel tractor
Need diagram on how to hook up 6 volt batteries
2 Suggested Answers
  • 14 Answers
SOURCE: Battery polarity
yes it is correct it is just the way it is
Posted on Aug 17, 2010
How do I connect the batteries under the steps 1 12volt for starting for the motor and two 6 volts for the coach I need to buy a manual for this r.v. it,s a 1998 national dolphin the electric pages
Hi James, The link below is a youtube video showing how to hook up two 6 volt batteries in series to product 12 volts, If this isn't the right video then check out the other videos down the right side of the link page, I hope you find what you're looking for..........CHEERS.. How To Hook Up Two 6 Volt Batteries In Series To Produce 12 Volts
Apr 24, 2016 | Cars & Trucks
How do I hook a 6 Volt Battery up on Farmall Cub Tractor
look for positve on battery a + sighn is what you are looking for on battery then find positive battery cable in tractor no witch it between pos cable neg cable hook neg to battery fist to battery then hook up positve cable ready to start
Sep 02, 2014 | Garden
Alternator wiring diagram on farmall M tractor
from scratch... well are you using the factory style of alternator or something different as you didn't mention the age and it could be: 12 volt positive or negative ground, or, 6 volt positive or negative ground. Or do you have a starter/generator or ??? Further research suggest you have a generator which would mean you have a voltage regulator somewhere... SO please help us help you. We need to identify your system before we can help... Pictures would be great. Numbers would be good, type of battery would help...
Aug 29, 2014 | Garden
2001 sportster battery not charging
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Sep 22, 2013 | 1993 Harley Davidson FLSTF Fat boy
Need a cable jump to start my harley all the time
Sep 03, 2013 | Harley Davidson Motorcycles
Engine management and battery light come on
Jul 13, 2013 | Harley Davidson XL 883 R Sportster...
Battery drain
17. For a free wiring diagram please visit the website below and good luck.Harley Davidson Wiring Diagrams and Schematics
Apr 28, 2013 | 2001 Harley Davidson FLHTCUI Electra Glide...
Battery wont stay charged
Hi Repoman37200, perform the following tests:
Mar 31, 2013 | 2006 Harley Davidson FXDWGI Dyna Wide...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
100 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Tom Chichester
Rod Newman
Rod Newman
Level 1 Expert
Are you a Farmall Toy Expert? Answer questions, earn points and help others
