Question about Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
Five key on my board that are not in funtion.
The 2 l.letter next- the tab key and the other i next to the "A key". There are the firt 2 number beneath the F1 and F2 .
  • 76 Answers
Buy a new keyboard
Posted on Mar 12, 2009
Inputting names. Three letters on keypad. how do I select the letter I need ?
You have to press 2 keys for each letter. Example - Bob - Press the letter B then press 2, next press O then press 3, next press B then press 2. The number key tells which letter out of the 3 letters that you want to use.
Nov 14, 2015 | Cell Phones
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
HOW TO SWITCH BETWEEN NUMBERS AND LETTERS
I'm guessing this is on a laptop or mini keyboard? You have managed to turn them number lock on. To be able to use the letters again on the keyboard the number lock feature needs to be turned off. This varies depending on the model of keyboard/laptop. One thing that may help is using the fn (lower left on keyboard) key on laptops (funtion key) and while pressing this tap the Num Lock key, usually at the top right of the keyboard.
difficult to be specific without knowing the exact make/model.
Dec 08, 2013 | LG ELECTRONICS Remote Control 26378154...
How to write letter verifing address
Instructions
    • 1Before you begin, set your marginicon1.png 1 inch from the top, 1 inch from the bottom, and 1.25 inches on both sides.
    • 2If you're using letterhead, there's no need to type in your name and address. If you're using plain white paper, type in your name, address and phone number (phone number is optional), centering the text. Make the font in this portion of the letter slightly larger than the rest of the text. You should also type your name, address and phone number in boldicon1.png type.
    • Sponsored Links
    • 3About four lines down from your name and address, type the date in full after strikingicon1.png the "Tab" key seven times to bring you a little further than the middle of the page. The date should be typed in full like this:
      February 1, 2009.
    • 4Four or five lines down from the date, at the left hand margin, type the name and address of the person you're sending the letter to. This portion of the letter is called the inside address. If the person you're addressing the letter to has a title, type his or her name first, then type in a comma, space once and type in the title, such as:
      Jamie L. Mulligan, Manager
    • 5Two lines down from the inside address, strike the "Tab" key seven times and type in the subject line. The subject line tells the recipient what the letter is about. In this case, it should look like this:
      Re: Verification of address
    • 6Two lines down from the subject line, type in the salutation. The salutation could be Dear Sir, Dear Ms. Mulligan, Gentlemen, or To Whom It May Concern (if you don't know the name of the contact person). The salutation should look like this:
      Dear Ms. Mulligan:
    • 7Two lines down from the salutation start the body of your letter five spaces in from left margin. The body of your letter should start out saying something such as:
      I am writing you this letter to verify that 101 Washington Street, Lynbrook, New York 11593 is the address I should ship your order to.
    • 8Two lines down from the body of your letter, after striking the "Tab" key seven times, type in a complimentary closing such as:
      Very truly yours, or
      Sincerely
    • 9Four lines down from the complimentary closing and in line with the complimentary closing, type your full name in, like this:
      Jamie L. Mulligan
    • 10Sign your name in the space between the complimentary closing and your typed name.
Read more: How to Write an Address Verification Letter ' eHow.com http://www.ehow.com/how_4745362_write-address-verification-letter.html#ixzz2DRXhelUj
Nov 27, 2012 | Computers & Internet
Keys are not matching up . When i type certain letters, it displays numbers. Example. press k, and displays 2. Must hold funtion key to get correct letter.
Your number lock is on. Look for a small picture that looks like a calculator on your keyboard keys (possibly on one of the F keys at the top). Press the Fn key plus the key with the calculator pic to turn number lock off.
Jul 19, 2010 | Twinhead Durabook N15RI-2 Notebook PC
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
WHAT ARE THE THE HOT KEYS
Hot Keys are either a single "Key" such as say the Ctrl button, or even a letter or number Key, on the keyboard or a group of "Keys" say Ctrl-Alt-Del, Shift- Alt-1, whatever. Usually the keys have a funtion assigned to them, and when the Keys is/are pressed on the keyboard, a certain action happens.. usually these are pre-programed OR user programed. Hope that helps.
Jan 21, 2010 | Tripp Lite B034-002-R 2-port KVM Switch
The function key is stuck on my Dell laptop
Just press the funtion key and the Numberlock key
FN + NmLk (Usually on the same key as delete)
Please rate this a fixya
Feb 08, 2009 | Dell Inspiron 1501 Notebook
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Spanish language
Press alt + number keys (101 or 465 0r any number)
Sep 08, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
32 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
