Question about Brother DCP-7040 Laser Printer
My brother printer 7840W showing on screen stack copies sleep. what shall i do to resume printing?
  • 3 Answers
SOURCE: Take Off Sleep Mode
(same response posted in another thread)
The issue is NOT the sleep mode)/
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Posted on Mar 21, 2009
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
  • 265 Answers
SOURCE: How do you reset a Brother MFC-7840W printer to
Menu * 2864 (within 2 sec.), 0,1, when 'maintenance' appears, press 0,9 to exit.
Posted on Dec 11, 2009
  • 24 Answers
SOURCE: my brother mfc-7840w printer keeps telling saying
The drum is the photosensitive roller that the image is charged onto so I'm afraid cleaning the corona wire won't help. If the drum is removeable try reseating it, otherwise it looks like you may need to buy a new drum kit for it.
Posted on Apr 28, 2010
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
Mfc 7840w keeps jamming
use a 20lb paper in lieu of regular copy paper, works for me
Jan 21, 2013 | Brother MFC 7840W Printer
How do I print double sided?
Since this is not a duplex model you will need to copy one side and put the copy back in the drawer and copy the second side of the original.
Jul 14, 2011 | Brother MFC 7840W Printer
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
Why does my Brother printer goes into Sleep mode and I can't print??
I have copied in the illustrated instructions for resolving printer status is Offline or Paused. (For Windows®) but if distorted please view here.
The printer status is Offline or Paused. (For Windows®)
Description:
To solve the problem, please see the following:
  • If the printer status is Offline:
    Check that the printer is online using the following steps:
    VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
    1. If the LCD screen is blank, then the Brother machine is not powerd on the machine to see if it wakes from sleep mode. If it does not, then verify that it is plugged into a working outlet and any power switches are turned to the ON position.
    2. Check the LCD screen for any error messages. An example would be "Paper Jam" or Ink/Toner Empty". If the LCD screen shows an error troubleshoot to clear the isssue indicated.
    CHECK THE PRINTER STATUS
    NOTE : These steps or screens may differ depending on the operating system.
    1. For Windows® XP Users:
      Click Start => Printers and Faxes
      For Windows Vista® Users:
      Click Start => Control Panel => Hardware and Sound => Printers
      For Windows® 7 Users:
      Click Start => Devices and Printers
    2. For Windows® XP and Windows Vista® Users:
      Right click on the icon for your Brother machine and choose Use Printer Online.
      Double click on the icon for your Brother machine => See what's printing => Printer => Use Printer Offline (Take the checkmark off.)
Note If the problem still continues, do one of the following:
  • If you find the Related FAQ's at the end of the page, click it and check another solution.
  • If you don't find the Related FAQ's, please contact Brother Customer Service from "Contact Us".
  • If the printer status is Paused:
    Right click on the icon for your Brother machine and choose Resume Printing. (If the menu reads Pause Printing, there is no problem in the printer status.)
    Double click on the icon for your Brother machine => See what's printing => Printer => Pause Printing (Take the checkmark off.)
    If this does not solve the problem,
    Double click on the icon for your Brother machine and choose Printer => Cancel All Documents.
    Double click on the icon for your Brother machine => See what's printing => Printer => Cancel All Documents
If you are using Windows Vista or Windows 7 please view here.
Trust this is helpful.
Dec 17, 2010 | Brother MFC 7840W Printer
MFC-7840w printer, how do i take it off sleep mode?
  • The control panel features a series of buttons as well as an LED "Status" screen.
  • Press the "MENU" button. Go to INITIAL SETUP, select "FAX" select "RECEIVE MODE" change to F/T
  • If you are using the Brother on a line by itself, set it to "Fax." If you are using the Brother on a line that also shares a telephone, set it to "Fax/Telephone." If you are using the Brother IntelliFax along with ananswering machine, set it to "TAD." Once you set your IntelliFax to the appropriate mode, the unit will leave "Sleep" mode and be ready for use.
  • Select "GENERAL SETUP" go to "ECOLOGY" and #2 is SLEEP TIME = adjust to 60 sec. This keeps the machine from becoming idle/sleep mode for a longer period.
    Sep 25, 2010 | Office Equipment & Supplies
    Drum error message
    To reset MFC-7840W drum count use the following steps.
    1. open the front cover (leave open).
    2. Press clear/back.
    3. Then confirm the new drum install by pressing 1.
    4. The display will indicate accepted.
    5. Then close the front cover.
    This should be done each time the drum unit is replaced.
    Jun 18, 2010 | Brother MFC 7840W Printer
    Brother HL1250 keeps showing 'DRUM' light & printer will not print. Printed great & then stopped with drum light. How do I re-set. I know drum is OK. Thanks. Herschel Beard
    you can reset your drum by opening the front cover and then press the resume buttom until all the LED light up...then release the button and close back the front cover...
    you can check your printer setting by press 3 times the resume button... tap, tap, tap, and it will print a copy of setting page for u..
    May 24, 2010 | Brother HL-2040 Laser Printer
    Documents are smudged on brother mfc-7840w
    just clean the toner and try.
    Have a nice day and do not forget to rate please...!
    Feb 03, 2010 | Brother MFC 7840W Printer
    Print not working on my brother MFC-665CW
    Do you have several attempts showing in your print que? Go to control panel, then printers, the double click on your Brother printer icon. See if there are documents stacked up. If they are, Windows will not send anything to the printer until all documents are printed in order. I hope this fixes your problem. Thanks for using Fixya.com
    Jan 26, 2009 | Brother Multi-Function Center MFC-665CW...
    Brother DCP-7040 Laser Printer Logo
    62 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
