Question about Toys
Syma s33 transmitter will not sync with heli pushed left stick forward and back still no response from heli
4 Suggested Answers
SOURCE: my syma s 107 copter
Try setting the heli down on a table and with the transmitter behind the heli, turn the throttle up until the blades start spinning. If that doesn't work, then I don't know how to help you.
Posted on Oct 04, 2010
  • 3 Answers
SOURCE: i bought 3 of the
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
Posted on Nov 07, 2010
SOURCE: my heli syma so31 with gyroscope won't play but
using the left stick push it forward then down to bottom the light on control should stop flashing this means it is synced with chopper
Posted on Jan 09, 2011
My s33 2.4g flying only 1-2-3 feet from the grownd pls help me pls...
if the rotors have been damaged then the turbulence from that damage is probably slowing the rotation speed down and the electric motor is not powerful enough to get it any higher
file any burrs off or get replacement blades
Jun 20, 2016 | Syma s33 3 channel rc helicopter 2.4ghz...
Just bought a syma s33 and it doesnt seem to go in a forward direction just goes up and drifts where it wants
You need to Neutral (ZERO) the Controls before flying. One additional item to take into consideration is WIND... Many of these smaller units will not fly on a windy day. My first one would be ZERO in a 3 knot wind..
Jan 03, 2015 | Syma s33 3 channel rc helicopter 2.4ghz...
First time flight
Check to see if the antennas are in tightly and making contact. Check the batteries in the helo that are responsible for radio signal, not the ones for rotor power!
Dec 26, 2012 | Syma S032g Red Helicopter Electric
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Apr 03, 2011 | xheli 9053 Outdoor Volitation Metal...
I have a s 107 and it will not go forward or backwards. everything else seems to work fine.
This has happened to two of mine, fairly common problem if you keep hitting things with your back rotor.
Solution 1: Replace the tail assembly
Solution 2: Remove the canopy and put a small weight in the nose which will serve to drag your heli forward. No backward flight but it works better than a heli that just hovers.
Mar 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My syma s107g gives a flash light in the circuit board and does not work
fully charge your heli----turn on transmitter-wait 2 seconds-turn on heli
wait for blinking green led to stop blinking-turns steady.....rev up
with a quick full throttle and back to idle--happy flying
Feb 20, 2011 | SYMA Toys industrial New Syma S107 Radio...
My heli syma so31 with gyroscope won't play but there is lights both unit and the remote control.
Dec 31, 2010 | xheli Syma S031 Outdoor RC Helicopter
I bought 3 of the Syma S107 RC Heli's because it said the remote had 3 different channels. I see the Channel a,b,c on the transmitter but I don't see how I assign different channels to the 3 heli's and...
Oct 31, 2010 | SYMA Toys industrial New Syma S107 Mini...
My syma s 107 copter transmitter dont connect5 to helis.controller light blinks
Oct 03, 2010 | SYMA Toys industrial New Syma S107 Radio...
Toys Logo
212 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
