Question about Ronco 'Showtime' Rotisserie and BBQ Compact Model Stainless Steel
Cord gets very hot
Rotisserie does not smoke or anything like that however the plug and cord get very hot sometimes setting off the smoke alarm.
  • 3,368 Answers
That is a fire hazard, do not use it, it will start a fire and possibly kill you.
Posted on Apr 02, 2015
Where do I go to get a replacement if my smoke alarm has aged out.
If your concerned because it's a hard wired smoke detector (has 120v) any New replacement will work and they sell them at Lowe's, Home Depot, etc... there is typically 3 wires for a powered smoke detector, black and white (hot and neutral) red or yellow (to interlock with other smokes) Please make sure Power is OFF and this is a simple fix... I hope this helps ?
Feb 21, 2015 | Home
Have a US model Kalorik Rotisserie which I have plugged into GB socket and blown it!
1) Test the power cord for shor with A VOM or DVOM and repair or replace
2) Open and see the thermic fuse is open
3) tEST any wires touching the carcase
4) Test the main swtich for short and replace.
God bless you
Jun 25, 2012 | Kalorik Rotisserie DGR 31031
IF I LEAVE THE BATHROOM DOOR OPEN WHILE TAKING A VERY HOT SHOWER, IT SEEMS THAT THE STEAM FROM THE SHOWER SETS OFF THE ALARM. iS THAT SUPPOSED TO HAPPEN? IT SEEMS TO BE A RECENT PROBLEM.
It is a common "problem" that really is not a problem at all! It means the sensors on your detector are working properly. The first smoke that comes off of a fire is moisture burning off. (that is why a fire smokes white/pale grey but the smoke gets darker as the fire burns hotter but then once firefighters attack the blaze with their hoses, the smoke returns to the pale color but thicker) Your detector was designed to go off upon early detection of a threat, which is mimicked by the bath steam in nearly every manner.
Jul 30, 2011 | First Alert Sa303cn3 Battery Powered Smoke...
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
I have a 2002 525i bmw, sometimes when i crank up the car a big pile of smoke comes out, and thens goes away. the car runs great sometimes and then sometimes when i make a turn i can hear the valves rattle...
It doesn't have to run hot to be blown. Sounds like you have oil getting into one of the pistons when you make that turn. After a couple of times, it ruins your plugs and that's why you're getting a mis-fire. It sounds to me like the engine itself is blown. The pistons along with the plugs are firing (burning the oil that gets into the cylinder walls. It's time to look into a rebuild.
Jan 06, 2010 | 2001 BMW 325
Acer TravelMate Laptop, cord getting hot, not getting power
I would imagine the voltage regulator in the adapter brick it dying...it will fry your motherboard if it starts throwing off power spikes. laptops need good consistent power flow of the right voltage. Buy another adapter.
Sep 05, 2009 | UltraLast ULAC3660L For Acer Aspire...
Ronco 'Showtime' Rotisserie and BBQ Compact Model Stainless Steel Logo
320 people viewed this question
Top Ronco Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Ronco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
