Question about Pitco Frialator SG14 Deep Fryer
How do you tell if the gas valve on a fryolator is no good?
The fryolator coupling was changed,but it wont turn on.i am looking at the gas valve as being the problem.
    Problem Solver:
  • 11 Answers
You may need to be more detailed in what your asking, for most connections involve couplings! If you could write back with a full model and serial # and the full problem, I would be glad to help.
Scoota
Posted on Feb 01, 2009
I have a toro 14-38 hxl rider that wont turn over I have changed the starter and selanoid and still nothing is there something that could be hung up that wont let it start it wont even click when you turn...
take the Spark Plugs out and try again.
See if there is a lot of gas in the cylinders cause Hydro lock
Ethanol gas ruins needle valves in carburetors which cause gas to get into the cylinders. Tell your Congressman to stop the ethanol gas joke
Aug 11, 2013 | Garden
Tip
Gas Hot Water Tank Not Producing Hot Water Pilot will not stay lit Trying to...
Trying to light your pilot light and it keeps going out when you turn on you gas valve. This is a common problem when your thermo-couple goes out. The thermo-couple sends a small electrical charge to the gas valve to keep its self lit. When the unit calls for heat the pilot flame gets bigger producing more electric and tells the gas valve to open the main gas valve to the burner tubes. The thermo-couple is an easy item to change most of the time. You will need to follow these steps to change out your thermo-couple:
1. Turn off the gas (there is an inline shut off on the supply line before it reaches the gas valve, you need to turn this crossways to the pipe)
2. Locate the thermo-couple it will look like this and be attached to the gas valve
3. Unscrew the thermo-couple from the gas valve
4. Remove the other end of the thermo-couple from the pilot holder
5. Measure or take the old thermo-couple to the hardware or appliance store with you to get the proper length (there are many different lengths of thermo-couples)
6. Reinstall the bulb end at the pilot
7. Reinstall the threaded end on the Gas Valve (make sure not to cross thread the thermo-couple it should start by hand)
8. Turn the gas valve to the pilot position and hold down the red button wait a few seconds then turn off and do again (you will need to do this around 5 times in order to get the gas back up to the pilot light then try and light the pilot)
9. Try to ignite the pilot light.
10. Once you get the pilot light lit you will want to hold down the button for 60 seconds then turn the gas valve to the on position.
Here is an image of a thermo-couple (they will all look similar to this):
Thank you for choosing FixYa.com. If you have any further questions please post them and we will gladly answer them
Justin
on May 03, 2011 | Plumbing
When you first turn it on the gas will light for a couple of minutes then just run no heat. and sometimes it wont light at all. frustrating only 14 months old
check the thermostats in the rear of the machine, one is faulty , its telling the gas to turn off too soon,, remove the wires from them, with needle nose, and check for continuity, if you have that ,, then move to the next one, also, if you have the 2 coil system on the gas valve itself, one or both of those could be going bad,
Jul 28, 2011 | LG D2526 Gas Dryer
I have a sg14 fryolater that when main burner ignites there is a backdraft w delayed ignition...basically a little explosion...any ideas..gas valve?
check the thermopile if it is receiving enough heat from the pilot.
if your fryer is a new model one and little explosion happens during the start up, that is the new self cleaning burner feature which cleans burner face during start up.
Mar 26, 2011 | Pitco Frialator SG14 Deep Fryer
How can I repair a Honeywell VR8200C 24 Vac Dual Standing Pilot gas valve. I'm trying to find out what went wrong in the gas valve that does not light the pilot. Does anyone have a clue as to where to...
have you changed the thermal coupling, if not it works similar to a thermometwr. if bad it shuts the gas supply down as a saftey feature. have a good day !! this should fix problem.
Nov 20, 2010 | Plumbing
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
Used oven purchased in US to work in Trinidad and Tobago (Caribbean) Only LPG Gas is supplied here, it seems as if the gas type is not what the oven was designed for. Main burners fires up and then cuts...
Hi i was reading your problem go to the appliances parts store tell them you need a gas valve Regulator that will change it from lpg to natural gas its natural gas it needs on the the 10 psi i think it should go back on the 25 psi thats only Regulates the flow of gas to high an to low dats all..i can be reach babeboz2000@yahoo.com
Nov 14, 2009 | Blodgett DFG-100 Gas Single Oven
I'm trying to switch from NG to LPG
Here is the wat to do it the right way according to the manual look at page 9 it will tell you.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318201551.pdf
Good Luck
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Heater won't light
YOU HAVE A BAD THERMOCOUPLE. IF YOU LOOK AT THE FLAME you should see a little match size piece of gold metel connected to a metal tube like then screwed into the gas valve. what happens is when you light the pilot, the gas heats up one end of the thermocouple and the other end changes that heat into microvoltage. the gas valve senses the microvoltage , knows the pilot light is lit then opens the main gas valve. when they go bad they cant send voltage to valve and th valve locks out. you always have to start at off. then depress valve button and turn to pilot and light it. hold button down 3 minutes then turn to full open or main the thermocouples are cheap, call supply houses or service companoies till you find one that will sell you one. unscrew the thermo couple from the valve with a little wrench unwravel the excess tubing , size of a pencil lead in diametor, then the probe part usually slids up through a spring like holder, note position of old sensor before reoming. get end half of new sensor into good pilot flame. reuae old retainers or new ones that come with new t couple.
Oct 09, 2008 | Procom ML060HPA Heater
Pitco Frialator SG14 Deep Fryer Logo
184 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
