Question about Hyundai L90D+ 19" LCD Monitor
Gateway sheild theft mode display and everythings blk+white
I have a gateway modelgt5662 w/gateway 19" monitor.i have a gateway sheild, theft deterrence system that turns everything b+white and will not go away. I can unplug my computer for about 2minutes and plug back and everthing is color and ok, untill 4or5minutes then the gateway sheild is back and will not go away. Does anybody know how to get rid of this problem?The gateway sheild stays on in the middle of the screen.HELP!
    New Friend:
I had the same problem with my 30 inch and figured out how to fix it without going through Gateway or using EZTune....There shuold be a reset button on the main board inside the monitor. While the power is on push and hold that button for 3 seconds and that will stop that theft mode! For my board it was SW1 (Switch 1)
Posted on Dec 01, 2012
  • Jerry Winston Feb 12, 2015
    I forgot to add....You will need to drill a pin hole in the metal cover and the backing that line up with the reset button because once you unplug the monitor to reassemble it then it will go back into theft mode. So line up your holes and put the monitor back together. Once you have done this, turn the monitor on and wait for it to go into theft mode. Once it does this, use something like a toothpick, inside of a writting pen or anything that is not metal or conductive to push and hold the reset switch for 3 seconds. Problem solved.
The problem was repaired by, Calling gateway. You pull up the challange code #'s on the monitor. You tell gateway agent the code numbers, they tell you a unlock code. You enter that on your monitor. and thats that! You pull up the challange code by unpluging your monitor then hold the menu button on monitor. plug back in holding the menu button! larrygl.
Posted on Jan 27, 2009
Laptop screen is blank white gateway
I was say you will need to replace the screen. To confirm everything else is working hook an external monitor to the vga. You may need to press the FN key + one of the F# keys that may have an icon of a monitor to toggle the display to the external display. If everything works this way then replace the screen. You can usually find a cheap replacement screen on ebay.
Dec 19, 2012 | Computers & Internet
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: .
The EzTune software is available here: .
The user's guide and other documentation is available here: .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
The monitor is a Gateway FPD1975W TFT LCD Monitor. I do not know the age of the unit. As of late it will not turn on. When the power button is pushed it will just blink like it it in standby mode even...
It was released about 2006.
I do hope you do have the PIN to unlock it, otherwise you will have to contact Gateway.
Please read this:
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
It may have hardware problem inside due to bad caps.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 24, 2010 | Gateway FPD1975W 19" LCD Monitor
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
Gateway monitor 22"
I think the guys at have a fix for that.
Jul 11, 2010 | Gateway FPD1975 19" LCD Monitor
Theft disable menu pops up and won't go away and it keeps turning off my monitor
You need to install EZTUNE from Gateway, but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN.
Forgot your PIN?
User manual:
Apr 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Anti theft mode
If L90D you need a PIN number to unlock it.
Connect to your original computer and run Plug-ins - Theft deterrence to enter or reset PIN - or go to web site via software - see below
Under the ‘Plug-ins’ menu is the ‘Theft Deterrence’ option – a more accurate term than the ‘Anti-Theft’ sticker on the monitor itself. Why? Well anyone can physically steal this monitor from me. There is no Bond-like lethal gadget that would bring certain death to a would be thief. Rather, the theft deterrent is a PIN-based procedure that hinders the operation of the display once it has been removed from the host computer. Briefly, you register and store a PIN to a secure web site, then set a countdown timer. If the power and display cables have been removed and the monitor has been attached to a different computer, the timer counts down. If the correct PIN is not entered using ImageTune, the monitor will enter theft mode and display a large warning message. It doesn’t prevent the monitor from being swiped, but at least there's some satisfaction in knowing the thief can’t use it.
software called ImageTune that replaces the usual on-screen display (OSD) tools, arrives on an included CD. With it, you can adjust basic monitor settings such as brightness and contrast with a mouse instead of with the small, squishy membrane buttons under the bezel.
Apr 03, 2008 | Hyundai L90D+ 19" LCD Monitor
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
768 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
