05 dyna glide
The starter on your bike uses a solenoid that also manually engages the starter gear. Try lubricating the solenoid mechanism and verify that the mechanism does not bind or stick. Once you have the mechanism freed up, check the starter again. If it does not engage, replace the solenoid (or, while you're at it, just replace the entire starter assembly).
SOURCE: oil change
go to fixmyhog.com and purchase the fix my hog dvd for softail/dynas. it shows complete video for all the general harley maintenance. it's worth it's weight in gold for all the money it has saved me in doing my own maintenance on my 05 fxd. i have mantained my scoot since it was brand new. 29,00 mles later, it still runs great !
SOURCE: will a gas tank off a 5 harley dyna wide glide
It sure will!! You answered your own question. guess i get no points for this one.
SOURCE: how to change oil in 2003 HD FXD Dyna Super Glide
remove the drain plug from the oil pan, you will need either a 3/4" box wrench or a 5/8" box wrench and the drain plug will be facing forward on the the oil pan. It is easiest to remove this drain plug from under the right side of the bike. put drain plug back in after about 10 m,inutes of drain time and tighten to 18 ft. lbs. Dont forget to change the oil filter as well.
SOURCE: 2010 harley dyna wide glide. when I press the
Is the clutch cable adjusted correctly, you may need to adjust the cable so that the clutch is released more fully, there will be an adjuster on either end of the clutch cable - adjust it so that the cable is tighter - but there should be a little bit of play left in the clutch -
if this does not cure the problem you could have some gearbox damage,
The bike is still under warranty so take it to a harley dealers and have them look at it.
