Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
Why won't my rear pto engage on my john deer 4310
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
lester482529
  • 226 Answers
SOURCE: Engine starts and runs Great. When I engage the
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Posted on Jun 07, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
wadembly
  • 513 Answers
SOURCE: The mower blades on my John Deere stx 38 lawn
it sounds like the safety switch under seat is bad
Posted on Jun 28, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
8130 John Deere pto code 1883.01
Rear PTO Underspeed. Make sure correct shaft is installed. Restart vehicle and select proper PTO engagement rate in the CommandCenter. If code returns, have your John Deere dealer repair as soon as possible.
OMAR259982 8130 8230 8330 8430 and 8530 Tractors Block File OURX935...
Last website shows to me what appears to be a sensor just to the right of the icon A pointer, identifying the snap ring, in the top right photo. http://manuals.deere.com/omview/OMAR259982_19/gif/RW55322A.gif
Best of luck.
Dec 16, 2015 | John Deere Garden
1983 john deere 420 garden tractor thats stalling out when barely moving the hydrostactic lever or trying to engage the front or rear PTO
There are 2 safety switches on that unit as well. Most of them are right below the steering column in the firewall area. Search that to see if that unit has them. I'd be willing to bet one of them is faulty. Most are just a push button type.
Oct 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
Jon Deere mower LX277 won't crank
Try replacing the starter solenoid. If that doesn't do it, try replacing the whole starter.
May 05, 2012 | John Deere Garden
John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Apr 23, 2012 | Garden
John Deere 4410 PTO error code. One long flash, one short flash and then six short flashes.
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
Problem with John Deere L120 tractor
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Aug 09, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
347 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
