Question about Magic Chef Refrigerators
Ctn1511bew refrigerator doesn't cool
SOURCE: Freezer works great but the
details of problem not enough,but try the following.1.locate the temperature dial( a nob with numbers indicating range of temperature and reset it to the maximum),then wait and see it there will be any change.
Posted on May 11, 2011
rickead1
  • 1998 Answers
SOURCE: The top freezer is working but lower part
Hello Eddie111,
If you were to remove the rear panel on the inside rear of the freezer you would then be able to gain access to the evaporator coil, If when you gained access to the evaporator coil you then noticed any ice build up on the coil itself this would be called a defrost issue that your unit was having. This is usually due to one of three parts either the defrost thermostat, the defrost heater, or the defrost timer or in some units the adaptive control board would be showing a fault. Would need you to message me back further if you do have a defrost issue with your unit. There is also a small damper door that lets the evaporator fan motor blow cold air into the refrigerator side of the unit this damper door is controled by a thermostat that is found in the ceiling of the unit. Usually attached to the control knob that is located inside the freezer. So first thing to check for is that the fan is working on the inside of the freezer next thing would be if you have the defrost issue on the evaporator coil itself, and lastly you would check the damper door and the thermostat inside the refrigerator side of the unit. If you have any further questions message me back with your reply to the defrost question that I asked previously. Thanks again I await your reply
Rick
Posted on Jul 20, 2011
  • 115 Answers
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
  • 184 Answers
SOURCE: My refrigerator doesn't cool
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
The fan or blower has failed.
The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
The fan or blower
The timer device
The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Hoping that this will solve the problem of the refrigerator....
Posted on Aug 04, 2011
  • 184 Answers
SOURCE: Whirlpool refrigerator doesn't cool.
The fan or blower
The timer device
Good luck in fixing the problem....
Posted on Aug 06, 2011
Refrigerator cools but fan doesn't work to push cooling to the top
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | Frigidaire FRS26R4A Side by Side...
Refrigerator side doesn't get cold.
heatman101
Sep 06, 2011 | Samsung RS2630WW Side by Side Refrigerator
Freezer works/ refridgerator doesn't cool
heatman101
Aug 21, 2011 | Refrigerators
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
Refrigerator doesn't get colder than 55 degrees.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 19, 2011 | Kenmore Refrigerators
Freezer is cooling but the refrigerator is not. This model doesn't seem to have a fan
heatman101
Aug 18, 2011 | Refrigerators
Freezer is cold enough but refrigerator doesn't get to temp. Any ideas?
heatman101
Aug 12, 2011 | Danby DFF8802 Top Freezer Refrigerator
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
heatman101
Jul 06, 2011 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
