Question about Hitachi 43UWX10B 43" Rear Projection Television
Red Power light won't go off
I have an Hitachi Projection TV 43UWX10B. When I turn the unit off, the picture goes off, but the red light stays on and you can hear that it has not completely turned off. This has happened once before and I was able to correct the situation, but I forgot what I did.
  • Anonymous Jun 25, 2008
    YEA MY WAS DOING THE SAME THING BUT NOW U CAN HEAR IT CLICK ON RED BUTTON IS BUT NO SOUND OR PICTURE U CANT CHANGE CHANNELS NO FUNCTIONS WORK ON REMOTE .BUT MY SURROUND SOUND THAT I HAVE HOOKED UP TO IT DOES WORK ON THE LAST CHANNEL IT WAS LEFT ON
  • Anonymous Jul 10, 2008
    POWER WILL NOT BOOT Hitachi 43UWX10B 43 in. Rear...PROJECTION.
If it is any comfort, my light has been on since I posted this and the TV has not burnt out yet.
Posted on Jun 27, 2008
I HAVE A SURGE PROTECTOR ON THE SYSTEM I TURN IT ALL OFF FROM THERE ALL DAY TODAY AND STILL THE SAME ISSUE ACCURS I DO HAVE ONE OF THE SMALL INDICATOR LIGHTS INSIDE THE UNIT THAT DOES NOT COME ON AT ALL .ITS A GREEN LIGHT NUMBERED DP23 I HAVE LOOKED FOR FUSES AND ONLY CAME ACROSS ONE SO FAR WITH THAT PANEL OFF IAM GONNA TAKE THE TOP COVER OFF AND LOOK THERE TO SEE IF THERE IS ANYTHING I CAN SEE WRONG IF NOT I GUESS A REPAIR MAN WILL BE OVER .
Posted on Jun 25, 2008
    UNLESS U HAVE ANOTHER SOLUTION THKS A MILLION
Try to unplug it for awhile like all day or do like i have and get one of those really cheep christmas light remotes and put it in line to turn off power and then every time that you turn off your set if the light dose not go out just turn off the power or have a repair man replace your power switch for alot of $$$$$.this work well for my system.
Posted on Jul 24, 2007
SOURCE:
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a Hitachi 43UWX10B that won't turn on. When I try, the red power light flashes, and I hear intermittent chirping. Any way to verify the problem and estimate repair costs?
Your convergence chips have failed.
Sometimes when they fail the TV will look 3D or distorted and sometimes it will just loose video and audio and chirp.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Can't turn tv on
TV DOES NOT COME ON, RED POWER LIGHT BLINKS ON THEN OFF
Jun 21, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
The red power light stays on
You may need to replace your Tvs convergence board. Go to www.partstore.com and type in your Tv model #. It is a simple swap procedure with no soldering. It costs about $80 or more. It takes 30 to 45 minutes to replace.
Dec 11, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B
you need the front panel PC board . You can get one most likely at the following link, just leave them an email and indicate your model number and what youre needing they will respond quickly.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | Hitachi 43UWX10B 43" Rear Projection...
43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
73 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
