Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Power working but burners and stove doesnt
Exchanged stoves. Then one that I had used a three prong plug. The kenmore had a four prong plug. when plug in stove got hot. turned element on and spark came from control board on top (I'm thinking that this might have fried the board). Tightened wires back and tried again now light come on, but no elements will heat. Not a rich guy (and getting poorer by the day) so just looking for some good dheap advise..thanks
    Problem Solver:
  • 22 Answers
Sorry brother, the board is fried.
Posted on Dec 25, 2009
I have a magic chef stove which has three prong and I just bought a he spectra glass top which it has four prongs could I use the three prong power cord on the glass top
tes you can use 3 prong the left and right wires go on left and right terminals on stove middle wire goes in the middle.
May 14, 2016 | Magic Chef Dryers
Spectra profile performance jb960k0d1cc has power but neither oven and stove work
what type of power cord does your range have? is it a three prong cord or a four pronge cord. If it is a four pronge cord you must make sure that the ground wire is attached correctly on the back of the range. You can refere to your owners manual that came with the range on how to hook up the range cord.
Nov 14, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The plug at the floor is a three prong and the one on the stove is a four prong what can i do to fix this
Hi johnnylowe55...
I will send you to a website that has three to four wire connections for dryers it should be the same for the stove.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Aug 28, 2011 | Kitchen Appliances - Others
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
The back burner of our Kenmore 30" electric free standing stove model # 911.94401301 is not working the coil is working it will heat up I am curiouse if it is the plug under the hood and is this...
This IS something you can fix
There are three likely causes, in most common occurence
there are fuses in the rear control console that blow
the socket does wear and require replacement
the temperature controller wires come loose, or the control fails.
check first for fuses
second swap the cables from the controller of the burner that doesnt work, to another controller to test if it is the controller or the socket.
  • swap cables with power disconnected and do NOT leave bare cables unsecured even while testing, better a live repairer, than a live wire
if the burner then works the controller is dead
if the burner still does not work, the socket is dead
the local parts store, or even a hardware store, will have the parts, even if branded frigidaire or ge or generic instead of kenmore, (Sears service is expensive and slow) many models of stove use the same socket, element, controller, clock, circuit board
Sep 10, 2008 | Kenmore Kitchen Ranges
Small electric kenmore oven
sounds like youve shaken or loosened one of the power leads into the oven, check the circuit breakers first, make sure they have not tripped, if not turn off hte breaker and remove the back panel of the stove youre only getting half power to the unit doesnt sound like anything magor at all
Apr 29, 2008 | Ovens
Zanussi gas stove
three problems with slow ignite on stoves.. first one is clean ignitors and burner caps. make sure that the caps and burners are correctly assemble. and make sure the stove is grounded correctly.. Do you flames have orange to yellow tips then there is a unburn carbon thst will form soot. soot productions is not achieving complete or efficient burning...again you may have dirty ot clogged burners..the flames should be all blue...let me know what you find out
Aug 31, 2007 | Kitchen Ranges
Burners - Oven not working
There is a problem with the 220v power to the stove. Indications are the neutral connection is missing either at the stove, in the plug receptacle or in the breaker panel.
Feb 24, 2007 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
248 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
