Question about Home Security
Will cold weather affect the closing of my Wayne Dalton DoorMaster
The weather has been below 15 deg for about 3 weeks. Recently my garage door will close and then when it reaches the cement it goes back up. Can the weather affect the system?
SOURCE: Garage Door issue
http://www.wayne-dalton.com/Files/ProductManuals/Residential_Garage_Door_Openers/DoorMaster/300640%20P4%207-9-2007.pdf
Posted on May 26, 2008
SOURCE: My Wayne Dalton garage door will open with remote but not close
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Posted on Jan 16, 2009
SOURCE: Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Posted on Jul 28, 2009
SOURCE: Genie garage door comes down and goes back up.
You need a general inspection of all related parts. Make sure none of the track mounting bolts have loosened leaving a misalignment of track segments. CAREFULLY with power off use fingers. turn EACH roller. Something as simple as a bad roller bearing can cause this, even a flat spot on a worn roller. Rollers can be bought at a home supply store. These are 2 most causes.
Posted on Aug 16, 2009
  • 3197 Answers
SOURCE: Cold weather came in and now the garage door
Try increasing the 'down force'. You will find the control on the rear of the motor unit near where all those white wires go. Increase it about 1/4 turn and try.
Posted on Dec 14, 2009
How do I reprogram a Wayne Dalton wireless keypad model 02-3039UH?
Usually by reading the instruction manual and doing what it says to do .at least it worked for my neighbor a few days ago .
Sep 07, 2015 | Wayne-Dalton Wayne Dalton 297138 or...
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
Wayne Dalton DoorMaster Model BDOr 2000 door will close but then goes back up immediately. How do I adjust it. Nothing is blocking the closure?
The Wayne Dalton Doormaster design is a mess. I've had two of them in my house for 10 years, with numerous repeat problems.
What you are experiencing is a need to recalibrate the door, but the underlying cause is that a linear potentiometer becomes non-linear, and the calibration drifts. Once this starts happening, it will continue to be a problem until you buy a new potentiometer, or clean the one you have. If you are handy, it isn't too hard to do.
Two other Doormaster problems are when the DC electric motor carbon brushes wear sand clog up the commutator, causing the motor not to run. Another problem can be corrosion on the back of the circuit board that causes erratic operation, but can be fixed by scraping the corrosion off the board.
If anyone still is having any of these problems, post here and I'll do a detailed writeup on these fixes.
Terry
Jan 25, 2013 | Sears Craftsman LiftMaster Chamberlain...
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have an old Wayne Dalton Doormaster Garage Door opener. It is definitely quirky, but when it stopped working this last week I called the Garage Door Guy to come and take a look at it. When he slid off...
Hi njitrrr,
Geez, that's a tough one! Other than getting a thick piece of Lexan and carving one out yourself....
There is a company, Ridout Plastics, that make some really tough plastic epoxies. I've used them and they are tough. As for gears, hmmm. I found their website and saw that they will fabricate a plastic part for individuals. Rare for a factory.
Here is the website that talks about fabricating parts: http://www.eplastics.com/Plastic/Plexiglass_Shape_Charges
Also, here's their site with the plastic adhesives: http://www.eplastics.com/Plastic/Adhesives?gclid=CJuT4pDOtKgCFUMUKgodNFTsDA
WeldOn #40 sounds likely. It might be worth a try to contact them about making a gear for you. Beats the alternative!
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Garden
Can i use the ''clicker'' model CLT1 with wayne dalton quantam 3316
It is compatible with Wayne Dalton opener manufactured between 1983 and 1987.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Apr 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door issue
stepper motor needs to be reprogram by a tech
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
19 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
