Question about Video Game Consoles & Games
I don't have access to Nintindo Zone
Error code 003-1099
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
What could I check to see why my abs don't work on my 95 chevy k1500? They haven't worked since I've owned the truck 6 years? I run large tires 315x16" could that be a problem?
Was the wire repaired? The only way to check your abs system is to have a service facility scan it for error codes. Auto Zone does some scanning for free, but don't know if abs scan is included. You could call your local Auto Zone and ask them. Larger tires shouldn't cause the abs light to come on. Good luck.
Oct 30, 2011 | Chevrolet Silverado 1500 Cars & Trucks
How to reset a computer to a 2005 chevy impala
If you don't have access to a scanner, go to you local Auto Zone, O'Reilly's, they will do it for you. If not that , disconnect the NEG battery cable for about 15 min. Hope I helped, TJ
Jul 30, 2011 | 2005 Chevrolet Impala
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
I would like to know the meaning of error code :051312-1 thanks
I don't know the meaning of the code directly, but I got around it by setting up MAC filtering on my router (you go into your router's settings, get your DSi's MAC address, which you can get if you go into the system information, and add it to your router.
Don't know if it'll work, but it helped me.
Jul 15, 2011 | Nintendo Video Game Consoles & Games
I can't connect to the internet. My DS is giving me Error Code: 51300. What can I do?
According to Nintendo's tech support website, error code 51300 means that the access point you are trying to connect to is not compatible with the Nintendo Wi-Fi connection. Try to find another access point and see if it will work then.
Jun 29, 2011 | Nintendo DS Lite Console
Error code 51331. unable to connect to internet. choose internet settings and then cofirm your connection.
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
(Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
(If you're not sure which is yours, or you don't see any wireless networks, click here.)
Asked to enter a security key?
If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
Don't know your router's security key?
Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand!
Linksys Netgear DLink
Belkin Apple 2Wire
All other brands
Select "OK," "Save Settings," and then "Yes."
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
The connection test was not successful - If the test was not successful, you will receive an error code.
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jun 28, 2011 | Video Game Consoles & Games
How do I find the error codes on my Santa Fe?
if your car's computer is reporting an error code, there should be a small light under the passenger's side of the dash that is blinking. This light will blink a certain number of times and then pause, then blink the same number of times again -- this is how you find your error code. Count the number of blinks in a cycle and then look it up in your User's manual or a Haynes manual to find the error code number. If you cannot find the blinking light, or if you don't have the time to look it all up or whatever, a mechanic should have a device that he can hook up to your car's computer to get the error code (you might even be able to rent one of these code readers from Auto Zone to do it on your own (the clerk at the store can help describe how to use it ... they might even help you with it in the parking lot).
May 31, 2011 | 2002 Hyundai Santa Fe
Nintindo error code 13207 keeps popping up.
the error code 13207 for nintendo 3DS is a problem connecting to the internet. If you are trying to connect your 3DS to the internet from a router try this.
  • Check for wireless interference, which can affect the signal strength to the Nintendo 3DS. To help minimize wireless interference, try the following:
    • Make sure that the Nintendo 3DS is within 30 feet of the wireless access point and facing in its general direction.
    • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off.
May 29, 2011 | Nintendo Video Game Consoles & Games
Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
  5. Click on "Wireless Connection" and then "Search for an Access Point."
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
May 07, 2011 | Nintendo Wii Console
Video Game Consoles & Games Logo
49 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
