Left speaker buzzing
No sound fom l/speaker
You may have some power wires ran along side your speaker wire. If speaker wires and power wires are routed the same way the speaker wire will pick up electrical interference.
Posted on Jan 27, 2009
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
Annoying sound
Hi Anita
Determine source of Buzz
Speaker --- Computers sound channel Amplifier
Left or Right channel
Can you hear buzz in earphones
Fan --- Speed changes with Temperature - insects or junk hitting on fan
CD --- Player mechanism - CD media left inside
Good Luck
Dec 06, 2013 | Toshiba Satellite Computers & Internet
Trailblazer buzzing coming through speakers
hi Scott, sounds like feedback try earthing your radio to the bodywork.
good luck Scott Craig
Aug 23, 2012 | Chevrolet TrailBlazer Cars & Trucks
No sound from left speaker on right deck. left deck is fine. confused! tried unplugging one at a time and only the right plug is working. is there anything simple i can do to rectify this problem? as...
To find out what the problem is try this, swap over the right and left leads from the deck to the amp. If the problem stays on the left channel there's something wrong with pre-amp in your amp. If it goes to the other channel (right dead) it's the deck. Next remove the wires to the cartridge to the deck with the fault. Make a note of how they fit on the cartridge before you do. With the amp connected to the deck and on. Touch (one at a time) each of the four wires with your finger. Two of them will probably produce no sound. But from one wire you should hear a buzz on the left channel and from another wire a buzz on the Right channel. If you get a Buzz on the left speaker then all the connects are good and the cartridge has gone. If you don't get a buzz, then there is something wrong with the left cable connector between the deck and amp.
Jun 01, 2011 | Technics SL-1210 Turntable
No sound coming out of left speaker, just buzzing
The amp inside probably has failed on the one side. The buzzing might be the ripple of the power supply driving into the speaker. DO NOT use it till repaired or speaker MAY be damaged.
Jan 16, 2011 | Kurzweil SP2XS Keyboard Home
Left speaker has developed a hum. Checked connections and all seems well. Sounds raspy like the speaker has blown.
This is likely due to a problem with the amplifier. You may have turned up the amp to the point of overdriving the speaker. The distortion at these high levels cause clipping and turn what was once crisp, clear sound into a muddied, garbled mess.
If the speaker is left connected to that source long enough, damage to the speaker and the amp may occur.
Without changing positions of the speakers: You can disconnect the affect Front or Rear L & R speakers and swap them (connect the L speaker to the R output of the amp and vice-versa). If the buzzing / hum "moves" to the other speaker, then the amplifier has the problem. If the buzzing / hum stays with the same speaker, the speaker has issues and is likely "blown".
Either way, it is probably not going to be a "cheap fix"
Jun 24, 2010 | Boston Acoustics VRS Micro Speaker
There is no sound in the left speaker when i play LP's. When i play CD's and the radio both speakers work, but when i play records sound only comes out of the right speaker. What's up with that?
Two possible reasons. First a faulty cartridge. With the amp on the phono setting, lift the arm up and you should see wires coming out of the cartridge. Make a note of how they fit or remove them from it one at a time. With your finger touching each wire, you should hear a buzz on at least two of the wires (one on the left and one on the right). If you do then the cartridge has gone! If you still don't get a buzz on the left, then the cartridge pre-amp has failed. Most likely an IC.
May 06, 2010 | Crosley CR79 CD Shelf System
I'vs had my HP Pavilion Dv9000 laptop about 2 months now, and it has been great. recently however sounds have only been coming from the right sound channel. The left side just makes a starng buzzing noise...
There is a problem is the sound card. The HP laptop should be still under warranty, take it to the supplier to get it repaired under warranty. If you try to fix it yourself you most likely will void your warranty.
Oct 24, 2009 | HP Pavilion dv9000z Notebook
Computer speakers
Try updating your drivers for your sound card.
Mar 13, 2008 | Logitech X-230 Computer Speakers
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
492 people viewed this question
