Question about Brother HL-5470DW High-Speed Laser Printer
How do I reset toner cartrige on brother hl-5470dw
  • 4 Answers
SOURCE: brother hl 2040 laser printer
On the brother printers, the fuser is often attached to the toner (they come out as one piece). If you look at the old toner, you will probably notice that it is longer than the new one. The extra piece that makes is longer needs to be taken off of the old toner and attached to the new one.
Posted on Nov 12, 2008
  • 133 Answers
SOURCE: resetting toner cartridge on brother hl 2040
Just push down the blue buttom for 1 min.
after you see 4 lights then it's okie now.
Posted on Sep 14, 2009
  • 6 Answers
SOURCE: Where is the toner reset button on the Brother HL-2040
I think there is none. It will reset when you install a new cartridge.
Posted on Oct 09, 2009
alpug
  • 1961 Answers
SOURCE: how do i reset my brother hl1440 printer after putting in a new
try this
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Please rate this answer and leave testimonial too!
Thanks
Posted on Nov 21, 2010
  • 20 Answers
SOURCE: Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Posted on Mar 05, 2011
End toner reset
Replace the toner cartridge and it will reset the page counter automatically.
Sep 15, 2014 | Brother HL-5270DN Laser Printer
BROTHER 5470 DW PASSWORD RESET
you don't need to. its "access"
Then if you want change ot from the web
Mar 10, 2014 | Brother International Brother HL 5470DW
Brother hl5470 toning on side of sheet
most likely Toner problem. Check also if the Drum does not have any Toner material glued on it
Feb 07, 2014 | Brother International Brother HL 5470DW
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
How do I pull out the toner cartrige of a HL 2040
Front panel of printer (manual paper feed is in the middle of this panel) has tabs on the right & left and will fold out and down. The toner/drum is right inside. there's an opening in the middle to grab it and pull straight out. The toner will separate from the drum unit by holding a small purple/blue tab on the left side down, and then lift up and out. Reverse this when putting everything back. remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, close up front door. Power off & back on and you should be set.
Jan 05, 2010 | Brother HL-2040 Laser Printer
Toner light
NEWER MODLES HAVE A CARTRIGE ESTIMATING PROGRAM THAT NEEDS RESET (you need to tell the printer that it has a new cartrige). SIMPLY....
1. OPEN THE FRONT COVER.
2. TURN OFF.
3. HOLD DOWN THE GO BUTTON AND TURN BACK ON.
4. ONCE ALL 3 LIGHTS ARE SOLID, LET GO OF THE BUTTON & PRESS IT 2 TIMES RIGHT AWAY.
5. ALL LIGHTS SHOULD GO SOLID AGAIN, WHEN THEY DO PRESS THE GO BUTTEN 5 TIMES IN A ROW.
THIS SHOULD RESET YOUR PRINTER AND LET IT KNOW IT HAS A NEW CARTRIGE (even if it doesn't)!
Aug 26, 2007 | Brother HL-2040 Laser Printer
Brother HL-5470DW High-Speed Laser Printer Logo
274 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
